You sound as if you're describing my Philips life.
Just had yet another soundbar die on me a couple of weeks after warranty ended. It's a curse.
Anyway, I had a few more hours of use with the 1000X and will share a few notes. I guess my use case isn't very common... I had them on while doing stuff in the house while listening to an audiobook. This means background noise varied a lot (from vacuum cleaners to water and noises of cooking stuff).
Won't comment on audio quality or NC, but I can comment on some aspects:
1) There are some creaking noises from the plastic frame. I can ignore them, but if you're paying attention (which I was, given previous reviews) they can be annoying. It's a bit too much, so I find that disappointing. They increased a bit with use, as out of the box they didn't make as much sound. But by use I'm talking about 1h or so. It's very fast.
The use case of the audiobook made it more audible since there are gaps between words/sound. This is audible when you move your head, but I've noticed that in silence, even if I don't move my head and just clench my teeth hard, that's enough to make them creak. They create a bit of a vacuum-feeling and being tight to the ears makes the whole structure microphonic.
Right now I'm typing this while having them on (and powered off) and I can hear the plastic sounds when I move my head even minute distances. Or eat something. The tiniest pressure just makes them creak like the wood in a caravel. They have a lot of isolation even when off, so the tight/closed design definitely makes the plastic creaking worse. When I switch from the 1000X from the Z1R I hear no noises but it's as if I no longer have headphones on, the isolation seems gone.
2) Pads get a bit hot with use. They're quite tight, which helps with isolation but makes it hotter. I did not find them to bee too clampy or comfortable tho. Except for heat, comfort is fine.
3) Touch controls are just awesome. I don't understand the reviews saying they're tricky to use. They're not, once you figure it out, it's super simple. I recall pausing my audiobook while cleaning a fish (literally) in the kitchen... I just used the clean side of the back of my hand to double-tap the cup, something impossible with normal button controls. Volume/Pause are super easy, and so is the temporary mute that amplifies external sound (again, just using the side of your hand is enough to trigger it. which I tried while having my fingers dirty with dinner ingredients).
Overall... I like them, but the plastic frame noise annoys me, especially if having them on with the sound paused or audiobooking (due to the pauses in sound).
Not going Bose after having experienced the touch panel, so I'm either returning them + going back to IEMs while waiting for something better or I'll keep them and learn to live with the creaks. (unit cost me 315 EUR at Amazon.es, btw). I'm going to keep them for a week and figure out what to do. Excluding the plastic creaking, I have no reservations. Still, buyer beware.
In summary:
-Plastic frame noises: bad
-Comfort: Pretty good
-Touchpad controls/Features: Awesome
-NC/Audio Quality: (?/not commenting)
