Raketen
- Apr 5, 2010
It's like using it on a high impedance output. The 8:1 ratio (i.e. output impedance is 1/8 of the IEM/headphone impedance) is generally a good rule of thumb to stick with as it offers sufficient electrical damping for most cases.
Cables introduce some measure of impedance to the output impedance - however, normally and proportionally speaking it's ridiculously minor. However, say you have a 1ohm cable paired with a 1 ohm output, you now have effectively 2 ohms output impedance. If your impedance of the IEM is say 16 ohms, not a problem - damping ratio is still high. Say the impedance is low like 4 ohms, and the output impedance is 2 ohms - your damping factor is now a problem.
That's why the IEX1 is silly - with a sweep, there were times where impedance was so low the LCR meter just gave up.
Thanks for reply- just to clarify: Was referring to the graphs that compensate two measurements at different impedances to illustrate where in the FR they are affected by what you describe- WIth respect to how deliberately lowering the ratio by incresing zOut can at times have a positive effect on FR (subjectively speaking, i.e. why some people prefer Andromeda w/ a Walkman or IEMatch, or IMO Massdrop+, ATH-IM02... sometimes even part of design intent, as I understand with certain multi-BA CIEM in the past which had low impedance but were tuned with high impedances of live monitoring & wireless stage gear in mind).
