thomas
Who needs headphones when there's the JVC MX-GT80?
- Jun 22, 2001
pedexing: How did you determine that the 915 uses 40 second memory? My results on the D-ej01, which should use the same circuit as the 915 always has a maximum of about 10-15 seconds. (I can actually stop the disc from spinning on my CDP, and count the time before it skips, if you are just shaking it, the cdp can almost always recover inbetween shakes and partially refill the buffer) Its actual antiskip performance is on par or better than almost all 40 second memory players because the read heads can recover after a shock much faster than older players.
The sound is very mushy and distorted through the headphone out (particularly with low-impedance headphones), but that is strictly an issue with the quality of the headphone amp and RF pickup...
In contrast the line out is the best i've heard, and probably one of the best of any portable. There are absolutely no compression artifacts, and sounds more detailed, "airy", and smooth than any other portable, almost as good as a home cdp. (many have noted this; even kevin gilmore uses it with his portable Stax over "classics" like the 777) which makes it seem extremely unlikely that compression is involved. (and compressed 10 second memory would be totally out of place in a modern CDP, much less a top-end CDP)
Most likely, the new CDP's ADDED option of compression- As sony and panasonic each try to release new models each year, they constantly try to "one up" the other in size, weight and battery life. There is not much room left to go for any of these criteria, particularly battery life- they've already redesigned the motors, electronics, removed the LCD from the main body, cut down the power of the headphone amp, etc. THe latest power saving feature, used on all CDP's after the D-ej01, is to quickly fill up the antiskip memory, then shut off the transport until data is needed again... With 10 seconds linear, it can only shut off for about 5 seconds before having to power up again, whereas with 40 seconds compressed, it can power down for 30 seconds, giving substantial power savings... This would account for the sudden 13 hour increase in battery life from the 915 to 925 models, even though they use basically identical circuity (other than the option of compressed antiskip) and the same batteries.
