aos
May one day solve the Mystery of the Whoosh
- Jun 21, 2001
I was experimenting with this EJ915 over the last few days, powered through AC adapter, connected to my new portable DAC with optical cable. It worked great. However, on Monday I wanted to listen to it in bed and I didn't have enough free outlets there so I used external battery pack. What I got are frequent and intermittent glitches in the right channel, that make any kind of listening impossible. When it starts up sound is fine, then after about 10 seconds it starts producing very loud clicking noises in more-less random intervals.
My guess is, it swithes on some kind of aggresive skip protection when it runs on batteries only and the quality of sound suffers. I cannot notice this if it's plugged in my home receiver through the same optical cable, or through the headphone out. Now, I'm going to try to see if I can do something to my DAC to fix this, but the fix would effectively just either mute signal or repeat the previous sample for the duration of glitch - which is what receiver and the CDP have to be doing as well. So far the diagnostics of digital receiver chip in the DAC definitely shows that at least some of those glithes cause it to go through the "clock transition" phase where it re-detects the incoming bitrate etc. Basically, when CDP is fooling around with reading from/to buffer, it occasionally drops samples. So I guess, whoever was saying that the G-protection (the highest level I guess) reduces the quality of sound, was right.
