Another vote for Supra. Best and not expensive in Hifi terms
Sonnet Digital Audio: New kid on the block, well.. not really!
- Thread starter Fredoo
sahmen
- Apr 6, 2014
Is shipping to the US going to be complicated?Another vote for Supra. Best and not expensive in Hifi terms
Try below for USIs shipping to the US going to be complicated?
https://www.madisoundspeakerstore.com/supra-cables/
sahmen
- Apr 6, 2014
Thanks. I am hoping they'll perform better than what I already have.Try below for US
There is a review of Pasithea posted on YouTube by someone who owns May DAC.
FOUNDERZERO
Anyone know if it's possible to make a HDMI -> RJ45 I2S cable to connect the HoloAudio RED to the Pasithea?
I think Holo RED is LVDS and Sonnet has buffered I2S. Not sure if it is possible.Anyone know if it's possible to make a HDMI -> RJ45 I2S cable to connect the HoloAudio RED to the Pasithea?
sajunky
Do not even try. It can damage HDMI port.Anyone know if it's possible to make a HDMI -> RJ45 I2S cable to connect the HoloAudio RED to the Pasithea?
KDS315
No, different voltage levels!Do not even try. It can damage HDMI port.
sajunky
Then try, but only on your own gear.No, different voltage levels!
sahmen
- Apr 6, 2014
Does anyone know where I can find instructions for replacing the USB module in the Morpheus with the I2S module? The ironic thing is that I did the same replacement about three or four years ago on my first Morpheus, and remember that it was rather uncomplicated, as I had very clear instructions on how to do it. Now, I do not know where to find those instructions, and I do not want to attempt the replacement again flying blind. Any help I can get from forum participants in locating that set of instructions would be hghly appreciated. Many thinks in advance.
LocalMotion
It's pretty straight forward. you just unscrew two screws on top of the board (it's on risers).Does anyone know where I can find instructions for replacing the USB module in the Morpheus with the I2S module? The ironic thing is that I did the same replacement about three or four years ago on my first Morpheus, and remember that it was rather uncomplicated, as I had very clear instructions on how to do it. Now, I do not know where to find those instructions, and I do not want to attempt the replacement again flying blind. Any help I can get from forum participants in locating that set of instructions would be hghly appreciated. Many thinks in advance
The tricky part is there a screw that is kinda under the overhang of the top edge, so the driver can't get to the screw straight up, kinda have to use an angle or have a tip that bends.
once unscrewed you lift of the back edge of board and gently pull it out at a slight angle (since it's in the external hole/port). Then just reverse than. angle it in the port, then gentle settle it into the board socket.
Curious, did you get rid of the Pasithea?Does anyone know where I can find instructions for replacing the USB module in the Morpheus with the I2S module? The ironic thing is that I did the same replacement about three or four years ago on my first Morpheus, and remember that it was rather uncomplicated, as I had very clear instructions on how to do it. Now, I do not know where to find those instructions, and I do not want to attempt the replacement again flying blind. Any help I can get from forum participants in locating that set of instructions would be hghly appreciated. Many thinks in advance.
I think he has 2 systems running. One with Pasithea and one with Morpheus.Curious, did you get rid of the Pasithea?
sahmen
- Apr 6, 2014
Yes, this is correct, although I am feeling a little "greedy" now about it, Nah!I think he has 2 systems running. One with Pasithea and one with Morpheus.
