That’s not going to work well, odd harmonics are more audible, some tube gear produces mostly 1st harmonic distortion, others produce almost equally high levels of distortion in higher harmonics and this all varies depending on overdrive levels, so it’s not even the same with exactly the same tube. Unless you can figure out some loudness normalisation level, you’re not going to know how much of what you’re perceiving is just down to differing levels.
of course i have oriented around the most prominent harmonic which is H1 with the plugin im using
i dont wanna replicate 1:1 one specific tube amp either, but get to a somewhat similar level of the most common (current) ones which seems to be around -60db for the most dominant harmonic, this is still audible imo
with the saturation settings im using input level equals output level +/- 0,1db, i think this is close enough for comparision
Yes, there is great variation between many plugins because they may be reproducing one particular tube distortion, all the various tube distortions, might be modelled on a specific tube or any combination of any of the various types of tube distortion. Remember as well that different tubes produce different distortions and even the same tube does depending on how much it’s overdriven.
unfortunaly there are not many linux native plugins, i might need to play around with wine for using VST plugins, i tried it before but wasnt able to get it working with carla, i might need to try again
That depends on your plugin, it might already be applying some compression as part of the tube distortion it’s producing or it might only be applying harmonic distortion.
atleast i think that the one im using is only applying distortion
What illusion? Be careful because there are vital variables here! The soundstage you perceive from this effect will depend on the following:
well the illusion of a greater soundstage, i dont think wider/deeper soundstage is the right word here... "larger" or more 3d soundstage matches more of what im hearing
1. What is the frequency content of what you’re distorting and therefore what harmonics/frequencies is the harmonic distortion going to produce?
2. How does that frequency response interact with the FR of your cans or the response of your speakers/room acoustics.
3. What is your personal HRTF and how does your perception respond to the above variables?
In other words, the illusion you get with the music your playing, on your equipment and with your hearing/perception is unlikely to be exactly the same if you change any of those variables and likely to be significantly different if you change all of them (EG. For someone else, playing different music on different HPs or speakers/room).
probably true, soundstage overall is a illusion not just depending on the saturation so it will change with very minimal changes but the "sense of a soundstage" stays kinda the same, im not sure how to name it tho
Either it is compression or just your perception of the harmonic distortion on the transients.
imo its the harmonic distortion on transients, well atleast my theory is that the distortion acts kinda as a new "noiselevel" reference point for the brain so the volume difference to the transient peak isnt "as huge" as without distortion and thus sounding less dynamic, its overall a slight but noticable effect, it makes the music more pleasant on dynamic speakers (which is funny since everyone demands greater and greater dynamics...)
Your post raises one other important consideration: The musicians (mainly guitarists and synth player) have carefully chosen/tweaked the type and amount of distortion on their instruments. The mix engineer has carefully chosen/tweaked the types and amounts of distortion they’ve added to some other instruments and groups of instruments and the mastering engineer has carefully chosen/tweaked the types and amounts of distortion they’ve applied to the whole mix. There shouldn’t be too little or too much. Maybe you personally prefer adding even more, just as you might prefer adding even more bass to the already carefully crafted amount of bass.
yes i agree, and this bothers me too (since im kinda a advocat of staying true to the source), for the most part i like the added distortion but i certainly found some songs where i prefer it not and its also mood dependent, added "tube" distortion makes it more pleasant/foot tapping like and without it sounds more "agressive/dynamic/"clear""
while i like it for the most part i probably will keep using plugins, so i can still disable it, also true tube gear comes with alot of downsides like degredation/running costs etc
That’s up to you of course but it’s lower fidelity, you’re not going to hear what the artists intended and it might work well (for you) on some tracks but worse on others (that maybe already have a great deal of distortion (or bass) applied).
well objectively speaking its indeed lower fidelity... but "is it really?", it doesnt sound "worse" so to speak, it mainly depends on your taste i would say, for one its lower fidelity and for another higher fidelity
which i also should mention is this ... i prefer rather -60db harmonics instead of -40db ... -40db was just to much for me, i like the mix of a slight tube effect but staying somewhat on the solidstate realm, you can definitely mix and match with the amount of distortion to make it work well for most music (for your taste)
and the more i listen to added saturation (and comparing) the more sensitive i seem to get, i was even able to spot -70db in a/b testing recently but the effect is nearly not worth mentioning so for me its either -55 to -65db or off
to get a worthwhile expierence with most if not all music its definitely less is more for me, tho depending on your mood -40db can be fun for a while too
(but this gets into territory where i would say electronic/rap etc sounds worse than without, specially because the less hitting deeper basses)
