Yeah there are pictures online, but one has to know what tube gear looks like to identify it in the pictures.
True but then I’ve worked at quite a few studios and used a lot of gear over the years. Most gear has it’s name printed on it of course, it’s just a case of knowing (or looking up) whether it’s digital or analogue and if it’s the latter then whether it’s op-amp or tube based. When I started in the business almost all studio gear was analogue, except for the recorders and certain effects (like reverb).
Isn't PinkPantheress for example a "bedroom producer/artist?"
In a sense. If you look up her album list, it’s mainly recorded and mixed by Jonny Breakwell at Battery Studios, a well known studio complex in north west London, famous for its analogue gear (including a lot of tube gear). How much she actually did herself in her bedroom is impossible to say, probably the samples and loops, maybe a fair bit more but this is the popular side of the music industry so what’s hype and what isn’t is probably known by very few and rarely made public.
My music collection mainly comprises of classical music. Very little of it is pop or rock music. My collection is a lot of classical music + Tangerine Dream and then "a little bit of everything": Jazz, New Age, Electronic Dance Music, Pop, Rock, Funk, movie soundtracks etc.
Even some classical recordings still use some tube gear. For example, the Decca Tree is still quite widely used and was designed for and works best with Neumann M50 mics (which are tube mics). I’d be surprised if Tangerine Dream didn’t commonly use some tube compressors. Jazz electric bass players often favour a tube guitar amp. Pop, rock and funk virtually always uses some tube gear. Movie soundtracks not so commonly but it’s still more common than you’d probably think. Air studios do a lot of film soundtracks and their standard procedure is recording the orchestra with a Decca Tree and M50s.
Then again you only need to find the correct parameters once and write them up, or better yet make a preset in the plugin.
There wasn’t a single setting even with the original hardware, let alone with a plugin. How you set the hardware depended on what you were recording and what you wanted to achieve, which gain stage or stages within a unit you wanted to overdrive to achieve a specific sound for example. So there is no “correct parameters” you can setup once and save as a preset. At best you can create presets as starting points but that takes time and in practice you often still end up spending considerable time tweaking them. This can often be somewhat of a creativity killer for experienced professionals. You generally don’t want to be spending ages focused on tweaking a single thing and loosing the “bigger picture” you’ve envisaged in your mind.
Mic pres are always tube in my experience.
Mic pres are relatively rarely tube based and most definitely NOT “always”. Avalon’s are probably the most common, although Millenia, Mercury, UA and API also had a tube mic pre model. Far more common are op amp based mic pres though, even amongst the vintage crowd! The Neve 1073 is probably the most famous vintage mic pre of all time and is still very widely used (as it’s been re-issued), Focusrite 110, SSL, API (SS versions) and other SS mic pres are far more common than tube mic pres.
I’ve no idea where you got that assertion from, unless you have a VERY limited experience of recording studios (which just happened to use tube mic pres).
G
