Sonarworks Headphone Calibration software
Oct 5, 2018 at 4:56 PM Post #1,187 of 1,377
Yes, I keep it about 80% with my Xs.:L3000:
Oct 9, 2018 at 2:51 AM Post #1,188 of 1,377
Just learning about Sonarworks. My question is when you factor in headphone mods, amp and dac sound characteristics does that mess things up when using your headphone specific EQ setting? In other words, when the Sonarworks team made the settings for the headphones, are they using very neutral, well powered gear?
Oct 9, 2018 at 9:01 AM Post #1,189 of 1,377
I'd think so, you can email them and ask them. They're the only ones who can answer your questions on that.
Oct 9, 2018 at 2:12 PM Post #1,190 of 1,377
I would hazard a guess that the only one of those to be concerned about would be headphone mods. Since their software is designed to correct anomalies in specific headphone models, any modifications would throw that off. The other variables you've mentioned would continue to "flavor" the music just as they would without Sonarworks, but wouldn't interfere with the corrections that it's making. The good news is that with a free trial you can try it and see. You either like it or you don't, makes no difference if it's "correct" if it doesn't sound good to you.
Oct 9, 2018 at 2:14 PM Post #1,191 of 1,377
It most certainly will. From what I've read, the sonarworks EQ corrections are based on an average of a number of headphones measured. Given that each headphone will have a slightly different FR compared to any other matching models, then this approach makes sense. Further, this means that mods will most certainly have an effect.
Personally I wouldn't be too concerned with the effect your other gear would have, as that'll affect any headphones and eq.
Oct 9, 2018 at 2:38 PM Post #1,192 of 1,377
Thanks for the responses. Definitely good points. There will always be variables.
Has anyone compared modded HD650 against Sonarworks?
I’ve ordered the HD6XX and just trying to explore options. Was going to mod it , but perhaps Sonarworks might work better for me.
Some of the mods are irreversible.
Oct 9, 2018 at 3:25 PM Post #1,193 of 1,377
I had the HD6XX and from my brief time using it with Reference 4, I much preferred them stock. To my ears they were a very pleasant listen right out of the box, certainly not ruler flat, but enjoyable.
Oct 9, 2018 at 9:52 PM Post #1,194 of 1,377
650 doesn't require a huge correction and it's native profile is quite pleasing on it's own but if your looking for reference flat that you can then profile away from to suit your preferences you cannot beat Sonarworks. One thing that would be nice is if they published the number of units used in the average profile to give a sense of it's stability.
Oct 9, 2018 at 9:57 PM Post #1,195 of 1,377
I use Ref 4 with my 6xx, but it's not the pronounced better experience I get with the X.
But I have tuned it and use it.:L3000:
Oct 9, 2018 at 9:59 PM Post #1,196 of 1,377
How do you think they'd compare to the physical mods people do on the HD650?
Oct 9, 2018 at 10:11 PM Post #1,198 of 1,377
Audeze LCD X:)
Oct 11, 2018 at 9:27 PM Post #1,200 of 1,377
I realize this is one of the oldest cliche's in the audio book, so forgive me, but to me Sonarwork's main function is to lift whatever veil exists in your setup. The better your equipment the less veil there is to lift, obviously, but when I A/B it there's ALWAYS at least some that it instantly lifts. I'm honestly baffled by anyone saying they don't like it. To each their own, of course, and I can understand someone resisting it on purely "keep it simple" grounds, but man, once I heard it there was no going back for me. I just hope they're good stewards of their product and continue to improve/refine it over time.
