Some First Build/cMoy Questions.
Feb 9, 2005 at 1:48 AM Thread Starter Post #1 of 4
Buffalo Bill
Hey, so I gots a few questions for building my cMoy, I guess about products. Anyways, this 'Hammond Constructed Case' that I've seen on zMoy and a few other cMoys here... where can I get it and how much? If I followed the tutorial from tangentsoft, will it fit nicely?
Also, for my LED, where do I buy those fancy caps that make a better finish?
http://www.dansdata.com/images/cmoy/amp640.jpg
(preferably something that looks like that in the picture)
Lastly, is there an alternitive to solder? I'm not very good; after alot of practice I'm still slow and make alot of clumps... or should I keep practicing?
Feb 9, 2005 at 2:15 AM Post #2 of 4
You can get these at Digikey, Mouser, Allied, etc. How much depends upon which one (size) you decide on. I wouldn't go with the smallest one, particularly for your first build. I can't recall whether Tangent's guide discusses sizes or not. I would probably build it, get it working, and put in a mint tin first, then as you get more experience, get a Hammond case.
You can get those at Radioshack, or any of the above-mentioned places.
Sorry, no alternative to soldering. Grab an extra board at Radioshack and practice on it a bit. Take your time (particularly when you start building. There are some soldering tutorials available online (do a search here for "tutorial". Make sure you heat both the component lead and the solder pad or whatever you are soldering it into, and use a small pencil iron (15-25W). Good luck.
Feb 9, 2005 at 2:46 AM Post #3 of 4
A tip on soldering:
If you are making globs of solder, your iron isn't getting hot enough.
Rememeber to keep your tip clean
Touch a little solder to the iron tip before you make a solder joint. This does two things, It finds the tip's hot spot and also generates more heat.
Then place the tip to the area where you'd like to make a solder joint and let it heat the area for a second and then apply solder a little at a time.
You don't need much solder for a good joint and it should be shiny after you're done.
Use a piece of steel wool or a dry sponge to keep the tip clean. Anything with liquid will reduce the tip's tempature.
As far as the led holders I would try ebay. There's a guy on there that sells them for around $0.40.
Any case that is 1" high and between 2.5 and 2.75" wide will work. The length depends on how many batteries you need 4.6" will fit two 9 volts.
Once you build a few you'll be able to shrink it down.
Feb 9, 2005 at 3:26 AM Post #4 of 4
Alright awesome! 'Nother trip to Radio Shack! I'll keep an eye out for some cases, too. Thanks!
