I'm kinda back in the cable skeptic mode, more because of the insane prices for commercial stuff, and the ensuing preponderance of last month's "revelation" on the used market, but we'll see. |
I hear you on that one man.Fully 80% of my system still uses either the Radio Shack 24 awg "rainbow wire",CAT-5 or the center conductor from a coax cable which also makes some pretty nice sounding interconnects in a simple "twist" pattern of two.
Funny thing here though.Coax is fairly flexable yet when you strip out the cnter conductor you end up with a
very stiff wire.Individual parts flex while the individual parts do not
got me to thinking (and we all know how dangerous that can be) about the relationship to the surface area vs length = flexability ratio.For some reason I am sure easily explained by others (probably a standard formula somewhere)the larger the diameter the more easy it is to flex.
Along those same lines (kinda of topic but stay with me here
) is the known fact that when you replace a car steering wheel with one of those cool looking but far smaller after market chrome spoke steering wheels it is
way harder to steer in anything but a straight line than it was previously and all due to the size of the wheel.
Take that to a volume control.Itty bitty controls on little amps have a very "coarse" adjustment range yet take a X2 larger knob and put it on the same pot and you have more
actual control to set the volume more precisely.Multiply the size again X2 and even more control etc.Just one of those weird things never talked about yet we all notice at one time or another.
so with wire you have a solid center surrounded by a foamed core then over this another layer in the PVC or other material outer jacket and your now formerly
very still and easily kinked solid conductor wire behaves as if it were multistrand !
That is until it gets SO SMALL that it then becomes flaxable but now it is fragile as hell and very easy to get a "kink" in.
Just no winning in audio and once you know everything is a comprimise you just set up the least amount of comprimise you can live with in a certain part of the design since a single solution never works for everything even in a single system.The rest we just deal with and pretend it is not there.
