Snow Leopard upgrade causing problems to RSA Predator
Sep 2, 2009 at 4:07 PM Thread Starter Post #1 of 4
nukular
When I plug my Predator into my Macbook Pro running Snow Leopard, I'm getting a problem where the audio is completely stuttering. Its only getting fixed if I go into the midi setup app, flipping to one channel, and then going back to two.
Anybody else having this problem? Its not major, but its certainly a pain from the past process of just plugging it in and getting good sounds....
Sep 2, 2009 at 4:26 PM Post #2 of 4
Would seem to be a bug in Snow Leopard.
Sep 2, 2009 at 5:49 PM Post #3 of 4
Works fine for me.
SL + MBP + Predator + JH13Pro
Sep 3, 2009 at 12:22 AM Post #4 of 4
While don't use a Predator - I do use USB (Pico dac/Kicas Caliente/HF-2/MacBook. Loaded Snow Leopard when received Fri. afternoon. No problems at all.
