SMSL M500 MKII DAC MQA ES9038PRO DAC Decoder & Headphone Amplifier
Dec 18, 2021 at 2:33 AM Thread Starter Post #1 of 11
smsl mandy
Sponsor: S.M.S.L
shenzhen,china
SMSL M500 MKII DAC MQA ES9038PRO DAC Decoder & Headphone Amplifier​
Click for more: https://hifi-express.com/products/smsl-m500-mkii-dac-mqa-es9038pro-dac
Descriptions:
Ten years of ingenuity, with professional technology and attitude, present you with a high-quality auditory banquet.
M5O0MKII uses the high-end ES9038PRO D/A chip of American ESS company, with the use of ES9311, ESS high-performance DAC dedicated power chip ES9311, power supply noise is as low as 1μVrms, the third-generation ES9038PRO circuit design, distortion is as low as -123dB, and more stable!
The brand-new self-developed CK-02 clock processing circuit greatly reduces clock jitter!
The latest XMOS XU216 USB solution
USB uses the latest second-generation XMOS XU-216, a true 32bit USB solution, with customized drivers for the transmission of various high-definition audio, DoP, and native DSD can provide better support.
  • PCM Decoding: 32-Bit/768kHz.
  • DSD Decoding: DSD512 natively.
  • Distortion: 0.00006%(-123dB)(Un-Wtd).
  • Headphone AMP Distortion: 0.0001%(-120dB)(Un-Wtd).
  • Headphone Output Power: 2Wx2(16Ω), 1Wx2(32Ω).
  • Gain Mode: 0dB(Low), +9dB(High).
  • Headphone Output: 6.35mm.
  • Line-out: RCA, XLR.
  • Dynamic Range: 131dB(XLR), 126dB(RCA).
  • SNR: 131dB(XLR), 126dB(RCA).
S.M.S.L Stay updated on S.M.S.L at their sponsor profile on Head-Fi.
https://www.facebook.com/S.M.S.LOfficiaI https://twitter.com/SMSL_Official http://www.smsl-audio.com/ smsl_mandy@126.com
Dec 20, 2021 at 1:12 PM Post #4 of 11
Is the Bluetooth bidirectional or receive only?
May 21, 2022 at 10:10 AM Post #8 of 11
I just ordered one of these to use primarily for DM, Metal and faster paced/aggressive music. I am stoked!
May 24, 2022 at 12:28 PM Post #9 of 11
@smsl mandy I was wondering if this can output signal from both xlr and rca at the same time. If for example, i wanted to connect the amp to both powered monitors and a sub.
Yes it can. Keep in mind that the gain through the XLR output will be higher.
Mar 6, 2023 at 11:35 AM Post #10 of 11
Loving my MKII so far...
But is it just me, or did anyone else notice that it gets hotter than other dac/amps (I also have ifi zen dacv2 and xdsd which is relative "colder" to the touch than M500)
Its as hot as my SMSL A300 Amp and Hiby R6 DAP
