maverick777
- Feb 15, 2006
Oh yea, I knew I forgot a pair of IEM's. Anyone look at the sub $200 range should definitely check out the Atrio M5/M8 (the only difference is the color and occasionally price).
Thanks for bringing those up tstarn06.
Perhaps you could add your overall impressions of the Atrio's to the mix to help compare them to the rest. I haven't owned the Atrio's before (yet)
. I did consider them before I got the SA6's. The reason I got the SA6's over the q-jays and the Atrio's simply came down to cosmetics. They all sound great with people on difference sides of the fence based on what they listen to and their sonic preferences. I liked the way the SA6's look and what the sound signature was described to be. It's hard to go wrong with the Atrio's as well.
They match very well, don't you think
This is probably not making anyone's buying decision any easier, but it's not supposed to be. Otherwise everyone would own the same IEMs. It's a very personal choice. Everyone hears things different and fit also varies from person to person. Best to buy them all from a vendor with a 30 day return policy if you can afford it and try them out.
