jaddie
Account deactivated by request.
- Mar 28, 2011
..and subscribed.
. Can it be that we need more sensitive measuring mechanism or the cable makers are trying to lie?
We can measure well below the threshold of audibility of any electrical parameter.
So....
Most people cannot understand many measurements of electrical parameters though, so it leads to a barrier in communication when discussing objectivism.
Yes, but some even who understand, still don't believe the measurements.
I think it is the old gut vs head problem. You can know something is so in your head, and have that gut feeling which disagrees with it. Pretty hard to ignore that gut feeling.
I have a question about cables, does the purity of the copper or stranded/solid wire actually have an impact on the function a piece of audio equipment?
Oxygen free copper (or OFC) supposedly means that there is no oxygen and therefore no copper oxide (which is a rectifier) in the cable, forming a myriad of micro-diodes that affect sound quality. The use of OFC cable is therefore supposed to improve the sound.
Try as I might (and many others before me), I have never been able to measure any distortion in any wire or cable. Even a length of solder (an alloy of tin and lead) introduces no distortion, despite the resin flux in the centre (and I do realise that this has nothing to do with anything - I just thought I'd include it. How about fencing wire - no, no distortion there either. The concept of degradation caused by micro-diodes in metallic contacts has been bandied about for years, without a shred of evidence to support the claim that it is audible.
I think my problem with equalization is the potential for distortion, then again no matter what you do distortion will always exist.
Thanks for the help Xnor. Yeah I figured cables really didn't make a difference, I once saw the results of a blind test in which one setup was used and the variable was the conductors from the amplifier to the speakers. In the test, one listen was done using an "audiophile grade" speaker cable and the other a coathanger. The results from the blind listeners concluded that the coathanger sounded better (obviously this was likely a guess, unless resistance or magnetic shielding came into play).
I've been getting into computers more than headphones lately (I take turns between my hobbies so I don't start to get bored). I need to learn more about sound science though and I'm really starting to like the objectivism approach to audio. I believe that a DAC and amp should be transparent and measure well, leaving the headphones to change frequency response (aside from maybe a little equalization to fix small imperfections). I think my problem with equalization is the potential for distortion, then again no matter what you do distortion will always exist.
Well, that's sort of like saying you can't taste salt in water. It depends on how much you mix in. If "distortion" includes all forms of signal alteration, then if you have enough of anything, there will be distortion. Even good, large gage oxygen-free copper, if you have enough, takes it's toll, and becomes easily audible at several hundred feet.
Galvanized steel fence wire? No problem measuring and hearing that, at at less length than copper by a long shot.
As far as degradation caused by micro-diodes in metallic contacts, if you haven't experienced an oxidized contact causing distortion, just consider yourself fortunate. It happens shortly before the contact completely breaks down, and is not all that uncommon, certainly documented, but perhaps only in the context of a contact reliability study. In short, just about any contact material except for 24k gold will oxidize given enough time and exposure to the wrong atmosphere and conditions. Low contact force permits oxidation growth between contacts, which is only semi-conductive, and depending on the materials, non-linear. We don't see the effect very often because good engineering has worked around it with high force contacts, or the right plating sealed off from the atmosphere. High current and voltages also break down oxidation, so you won't find this happening in speaker circuits very much. But yes, it exists, is documented and we do have to deal with it.
The way to think about that is to weigh the huge and clearly audible benefit of equalization against the minute and pretty much inaudible distortion of a halfway decent equalizer.
On my receiver, there is a direct bypass button. It bypasses all of the equalization and DSPs... and even the tone controls and just patches direct from input to amp to output with no processing. When I push that button, The soundstage shrinks, the tone becomes opaque, and the overall sound feels flat. Switch back in the processing and the whole thing opens up and becomes clearer. I'd never be satisfied with the sound of my system if I wasn't able to adjust it.
