Skeptico Saloon: An Objectivist Joint
May 3, 2015 at 1:23 PM Post #1,487 of 1,671
Don't you mean "some flac?"
No I meant Flak as in kaboom or heat.
May 3, 2015 at 2:26 PM Post #1,488 of 1,671
iTunes is a cluttered, clunky, mishmash of tools.
I have a massive collection of music, and iTunes handles it like a champ. It runs 24/7. Very fleixible and very stable. But I am on a Mac. May be different on a PC.
May 3, 2015 at 2:40 PM Post #1,489 of 1,671
I am on a Mac too. No stability issues but the interface is awful, and it tries to be too many things.
May 3, 2015 at 2:50 PM Post #1,490 of 1,671
Do you swim upstream on tagging conventions? I know a lot of people who listen to classical music do that and run into problems with iTunes.
I usually don't use the interface on my computer. Everything goes through my airport system, so the interface I use is the one on my iPhone. You might try that. It's pretty simple.
May 3, 2015 at 4:52 PM Post #1,492 of 1,671
Most people don't use the smart play listing feature because it takes a while to figure out how the script works, but if you set up some good criteria, you can really make your collection present itself to you in very useful ways.
May 3, 2015 at 8:57 PM Post #1,493 of 1,671
Yeah, the smart playlists are fun, I use them a lot.
One thing that often bugs me, though, is that the arguments can only be joined by AND operators, no ORs.
So if I want to collect all my Händel in one playlist, and I've been a bit sloppy with the tagging, I can't do it by asking for all tracks where: Type is "music" AND (Composer contains "Händel" OR Artist contains "Händel" OR Album contains "Händel" OR Composer contains "Handel" OR Artist contains "Handel" OR Album contains "Handel"), for example.
It can be done by using AppleScripts, but it is a bit of extra work.
May 4, 2015 at 12:53 AM Post #1,499 of 1,671
  You're imagining yourself as Abe Lincoln?
That's only making you look even more vain.
How could you possibly deduce that is beyond comprehension. Lincoln has been always depicted as having a Top Hat
http://americanhistory.si.edu/lincoln/introduction
http://www.smithsonianmag.com/history/abraham-lincolns-top-hat-the-inside-story-3764960/?no-ist
I dress nice in current fashion, no Top Hats in my wardrobe
May 4, 2015 at 1:00 AM Post #1,500 of 1,671
  So if I want to collect all my Händel in one playlist, and I've been a bit sloppy with the tagging...
The "sloppy with the tagging" is the problem though, not the playlist itself. You could always do a global search for "Handel" and correct whatever tagging problem is causing the problem.
