Singxer SU-2
Apr 17, 2023 at 12:43 AM Post #91 of 229
I removed CCHD957 and check the circuit, I found that the suppose to be regulator component may be not a regulator, it's pin out is not compatible with TPS7A20, this caused the pin1 of VCXO voltage almost short circuit to 4.8V (not sure why not 5V, some where drop the 5V to 4.8V), it is also abuse TPS7A20, connect it's 3.3V output to 4.8V. Do you have idea what component it should be? I think I cannot get it back after I swapped it out and replaced with TPS7A20.
The chip on my SU-2 has the following marking: T1IS
The part is TL331IDBVR.
Digikey has them in stock
Apr 20, 2023 at 2:23 PM Post #96 of 229
That is all. Thanks.
I got my SU2 turely work with external 10Mhz clock now after I solder the comparator on PCB tonight :)
VCXO voltage control voltage around 1.67V when running 45Mhz VCXO, 1.68V when running 49Mhz VCXO.
The sound is much detail now :) better than my DigiOne much more, when ran Crystek before, the sound quality is little bit better than DigiOne, it is great, success upgrade.
I am looking for good clock cable, I bought two low price clock cable, one is Sommer SC Classic MK II, one is Canare 5DFB, Canare is cheaper but it is slight better in detail.
Another good guy told me Harmonic Technology Digital Copper III 50 ohm is super in another forum, anyone use this cable and any comment ?
Apr 27, 2023 at 11:30 PM Post #98 of 229
@b0bb do you know in the attached photo component? I found external 10Mhz clock enter this IC component, then from another pin through 33ohm into FPGA.
Probably a Rohm BD4932 voltage detector.
This is a part of a crude sinewave to squarewave converter, this part is normally intended for generating microcontroller reset signals.
https://fscdn.rohm.com/en/products/databook/datasheet/ic/power/voltage_detector/bd48xxg-e.pdf
Jitter accuracy of your external clock is dependent on how consistently this part operates.
2% amplitude accuracy or 20000ppm variance, not exactly reference class.
Apr 28, 2023 at 12:00 AM Post #100 of 229
You are superb! From the pin out function, it is not BD4932 because actual IC pin 5 seems to be output, but BD49XX pin 5 is NC or VCC, but your guess is make sense!
The FN marking is the Rohm part, as far as how it is actually used, doing that work is up to you if you want to explore further.
Apr 28, 2023 at 12:07 AM Post #101 of 229
The FN marking is the Rohm part, as far as how it is actually used, that work up to you if you want to explore further.
Unless there has others pin out, actual IC and spec pin out are not match, so I guess they are not the same, you see the spec shows the silk screen pattern also not same as actual IC. However if use this kind of IC for sin to square wave conversion, it is really bad design.
Apr 28, 2023 at 12:10 AM Post #102 of 229
Those are the details you need to work out for yourself, the SMD marking books do not list anything else
Apr 28, 2023 at 12:21 AM Post #104 of 229
I think I just found it, it should be FIN1002M5X, a LVDS differential receiver.
Apr 28, 2023 at 12:36 AM Post #105 of 229
This would be worse than the first option, LVDS are digital signals, a sinewave is an analog signal.
The FIN1002 outputs a LVTTL digital signal, in effect this is the sine to square converter.
To make matters worse, the coax clock input is single ended / unbalanced not diffrential. LVDS works best with a differential input
