b0bb
- Oct 15, 2014
The original part in my SU-2 was specified at 150MHz.Hey there, thank you for the excellent run down of the mods you made to your Singxer SU-2. Would you be able to advise if using the regular NVE IL711-3E (110MHz) isolators is sufficient or one must use the speedy IL711S-3E (150MHz) model specifically?
110MHz may be marginal if you intend to use the higher sampling rates (1536k/DSD1024)
