Thanks again for the explanations. The interaction with the knob is crucial. When you are into the music, the device has to disapear, and volume needs to be able to be adjusted without even looking. The hand should find the way easily without looking. And yes, the knob needs to be large to be able to facilitate this.
Why do you say not to do that when you are actually doing it? It will really depend on how deep is the set screw, and if it allows to be separated enough from the front plate not to scratch it, and that is really hard to know before you have the knob in your hand, since it is not specified really... But your knob is perfect really, now it is a Luxman knob, not an aliexpress one LOL. I like it silver, contrast looks great, like in Schiit stuff.
Some I found on aliexpress:
https://www.aliexpress.com/item/4000123852606.html?spm=a2g0o.detail.0.0.51a0654bkidDtM&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=26c200c3-d109-4ead-9eaa-4fcc008c27e4&_t=gps-idcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:26c200c3-d109-4ead-9eaa-4fcc008c27e4,tpp_buckets:668#0#131923#77_668#0#131923#77_668#888#3325#1_668#888#3325#1_668#2846#8107#1934_668#2717#7565#702_668#1000022185#1000066058#0_668#3468#15609#253_668#2846#8107#1934_668#2717#7565#702_668#3164#9976#203_668#3468#15609#253
38x28 is this one. Very very like yours.
Another ones:
https://www.aliexpress.com/item/330...9#342_4452#5108#23442#993_4452#3564#16062#700
this one is available in 34 and 38:
Another ones:
