Hi guys
So, after a period of burn in and a few days of shorter test sessions I have some discoveries to share.
When the possibility to be a tester came up for a few of us,
@FredA came up with the brilliant idea to have a 5.5/2.1 mm 5V output on the back. This is an option but a very good one. I don't know the cost for it when ordering but I think it is worth much to have this possibility to power another small device. The Raspberry Pi 4 draws about 600 mA on its own. (Please see: h
ttps://www.raspberrypi.org/documentation/hardware/raspberrypi/power/README.md )
This means that if You not hook on other loads (disks or else..) on the USB ports You will have an over capacity (current) from the Simple Best Raspberry Pi player PSU.
In my case, I am using the 5.5/2.1 output right now to power my Mutec MC3+USB and it works excellent. The MC3+USB is a relative small load with a maximum of 10 Watts. I have it stacked on top of the Simple Best Rpi PSU. The MC3+USB is short enough to not cover the ventilating slots, on the top back over the RP4 location and on the front, over the heat producing components transistors, resistors underneath.
The cooling air inlet is under the back end, under the Rpi and the box full width, so the cooling air is supposed to flow from the low back end over the Raspberry Pi and up and out. The other flow is supposed to flow over the PSU parts to pick up and evacuate the heat and transport it up and out through the front slots. It works ok under cooler ambient conditions but the heat spreads around in the whole unit so the Raspberry Pi has a bit too hot during hot summer days when it is warm, also inside. I tried yesterday by adding a primitive test thermal barrier inside the chassi to see if I could separate the airflows and get better thermal conditions for the Raspberry Pi. Yes, it works and lowered the temperature for the Pi with about 5-7 grC. (I will also suggest Simple Best to add something like this as default)
The sound.
It is a more precise presentation I get with the Class A PSU feeding the piCorePlayer software I run in my Raspberry Pi's. It is a sophisticated sound with a more resolved and balanced sound. For me, listening a lot to acoustical and classical music this ”sound profile” is the right choice. I listen to many kinds of good music of almost all genres, and it works there too. If I was a ”bass head”, the right choice had possibly been the toroid transformer version of this unit.
The most surprising thing with this unit is the fact that the WiFi work this good. I use 5G and I have full strength and can play up to DSD256 and DXD 352.8K and 384k without any issues. It is a Class A unit so it gets pretty warm (about 41-43 grC on top lid). It needs good ventilation around it and should not be stacked direct above other warm/hot equipment.
In my case, I asked for a blue led shining on the front and I think it looks nice.
To sum this up..
For USD200 including a Raspberry Pi 4, I think it is a bargain. These small one card computers are here to stay and the market is huge. This way You get an excellent PSU for it and it will be a part of Your gear rig, not a hanging "add on" on the back. This device looks good where it stands. If You are running Raspberry Pi as Your player, buy it. It does a really good job on the music played. It is professionally built and powerful to stand for a long time. Who knows what computer(player)board it has inside in a few years. Don't mind that but the potential is there. This nice Raspberry Player box with Class A PSU from Simple Best definitely stays in my rig!
/Jan
ps. A few pics.
