Speedskater
- Dec 27, 2006
.......................................................... If you build speaker wires from CAT5 cable or run of coarse or fine copper strands with similar AWG they are all conductors of electricity. Will it sound the same? CAT 5 has high inductance a low capacitance. This is where some will say they should sound identical because its "just wires". True - YES. In reality every wire will be a "good" or "better" impedance match between components. This is where you can have different frequency roll off due to wires.
Actually if you bundle several Cat5 cables together, then connect all the stripes to one terminal & the solids to the other. The cable will have very low inductance and high capacitance.
The low inductance may increase treble response with some speakers. (Apogee, M/L)
The high capacitance may make some legacy & boutique amplifiers unhappy.
