I want to introduce an alternative to Shure AONIC 50, for home use: HIFIMAN DEVA. DEVA has bluetooth, but it is not like traditional bluetooth headphones, so you might not hear about it.
I have had Shure AONIC 50 since July. I liked its sound for music. I pay attention to vocals in music. So I want strong mid/vocals which does not sound recessed. I got that on A50. But A50 has small soundstage. Vocals, music, instruments are all in your face. I found that watching movies, A50 sounds 2-dimensional.
I was looking for value headphone that can provide more soundstage, but also has good music capability. I often find that sound stage vs mid/vocals are opposite. Most headphones with large soundstage do so thru V-shaped sound profile, which results in recessed vocals. So I need find a balance between mid/vocals and soundstage.
I was specifically looking at wired, either closed or open back. Since I will be watching movie at home in front of the computer, I'm good with wired. And I believe wired headphone at same price point will have better sound than bluetooth. I didn't mind if it was closed vs open back.
I narrowed down to these 2 headphones:
- HIFIMAN DEVA (Wired New $220, Open-box $190; Bluetooth New $300, Open-box $230)
- Drop + HIFIMAN HE-5xx (Wired $220)
I ended up getting DEVA open-box and that came with bluetooth unit. And after I compared DEVA vs A50, I found that DEVA is a strong competitor (and to me sounds even better than A50). DEVA is more detailed, has better instrument separate, and larger soundstage, than A50. The difference is quite significant. I just do one AB comparison, I can hear the difference. The downside of DEVA is vocals sound a bit further back and less in-your-fact than A50. The vocal difference is not as apparent. I have to do AB multiple times to pick out the differences. For me, for both music and movies, I have being picking DEVA over A50.
Do note that their application and usage environment is different. A50 is closed back and has ANC. So it is usable outside your home, on train, planes, walks, office, etc. On other hand DEVA is open back (obviously no ANC), larger, and bluetooth module is externally attached. So this is usable mainly at home. I tried DEVA on my daily walks around the neighborhood. It works, but clamp force is too low to have a secure fit while moving around. A50 definitely works better on walks.
This is my review of DEVA and comparison to AONIC 50, on the DEVA thread:
https://www.head-fi.org/threads/hifiman-deva-official-thread.928847/page-38#post-16077379
Some photos comparing the 2 headphones:
DEVA only comes in the light brown color. Shure has couple color choices and I got the black version.
DEVA has bigger and deeper ear cups:
Headband design is quite similar. DEVA headband is a bit wider, while A50 headband is thinner. A50 headband is padded at bottom (where it touches the head), where as DEVA headband is thicker and has padding on both top and bottom (but top padding is not really useful or needed).
