sharkz
Those Stainless Sharks are the best blades I've used and I only paid like $10 for 100 of them. I would like to try the Feather's some day, but I have been very happy with the cheap Sharks for the past year or so.
Well after mulling it over I've finally done it. Ordered all the necessary items last night and should be set to see what this whole shaving revolution will bring. I ordered:
Murkur classic
Proraso cream (eucalyptus & menthol)
Badger brush
100 derby blades
Hopefully this stuff will arrive in the next weeks so I can see what all the hubbub is about. The way I see it, the initial ~$70 investment is worth it considering the only thing I have to buy now is blades. Should be set on those for a while unless I want to try out others (sample pack maybe?).
The neck is the trickiest area at first. You really should not need any more passes there than anywhere else once you get the hang of it. One pass down, one against the grain. Since it is not a straight down pull with gravity, you will have to learn to put just the right amount of pressure.
KP
Perhaps I should have been more specific. There is a very small area on the neck that I can never seem to get smooth.
The rest of my face is fine. When I do go for it (trying to get that neck portion smooth), I'll often nick myself from too many passes.
I've seen some pretty risky techniques, such as The J-Hook and blade buffing. I could just be agonizing over it, but it does cause frustration.
Same here.
I only recently tried a feather and found it to be only slightly better than the Sharks.
For my money, I think I'll stick with the Sharks for the foreseeable future.
Hmm, I'll probably be grabbing these next time. I do love the feathers that I've got, but saving half my money for something thats just as good...that seems like a no brainer. But ive still got like 30 feathers left
The extra time you allow the soap/cream to stay on your beard will allow it to strip it of it's natural oils making it super brittle and VERY easy to mow down with a razor. Also, work on proper technique.
This works well. Let the soap/gel CREAM stay for a couple of minutes, it'll make it a lot easier to shave.
Fixed it for you.![]()
