I'm relieved, I thought it was just me. May I know what smartphone you use? Mine is Poco F3 (it's a Xiaomi subbrand).I can't speak for the Kato in particular but I also find a significant difference in power/volume between Bluetooth and wired..
Shanling UP5 - Our new flagship portable Bluetooth DAC/AMP
- Thread starter Shanling
I just found a solution! In my case, the culprit was the region setting. Apparently Xiaomi sets a volume upper limit on some regions and that includes my country. I tried changing it to the US and it works.I can't speak for the Kato in particular but I also find a significant difference in power/volume between Bluetooth and wired..
Yes, this make sense, as the volume in Bluetooth mode should be same s in USB DAC mode. It's possible that this was hitting the EU volume limit setting.I just found a solution! In my case, the culprit was the region setting. Apparently Xiaomi sets a volume upper limit on some regions and that includes my country. I tried changing it to the US and it works.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Is somebody else have this problem? I think that my usb c port is busted because whenever I touch the cable the music goes off and the unit changes its mode to bluethoot. Also when I am using the unit sometimes I get pops and even pops every 500ms like a beat idk why?
Most likely issue in cable or USB-C port. You can try different cable, if it doesn't help, please reach out to your seller for warranty.Is somebody else have this problem? I think that my usb c port is busted because whenever I touch the cable the music goes off and the unit changes its mode to bluethoot. Also when I am using the unit sometimes I get pops and even pops every 500ms like a beat idk why?
Yeah I have already changed the cable because I thought that the problem was there but the problem didn't go away .
holsen
My UP5 just landed and I love it. Came out of the box with latest firmware. Currently driving my EJ07M on Low Gain with volume at only 15 and it sounds amazing. I'm very happy with this device and the UP2 is now hardwired into my car.
Does anyone know if the UP5 will output a signal to anther device via USB C? I was thinking about using this with My Mojo 2 as a wireless receiver.
No, UP5 do not output data through USB output.Does anyone know if the UP5 will output a signal to anther device via USB C? I was thinking about using this with My Mojo 2 as a wireless receiver.
But you can use our M0, Q1 and M2X or any of our Android players for this.
djn04
- Nov 11, 2009
Does anyone else get a rattling sound from the volume wheel when you shake the UP5? If I hold down the volume wheel button I don't get the rattle or it's much less. It's probably not a big deal but want to see if it's common.
rlw6534
Mine doesn't seem to rattle (or it's so faint I can't hear it). Doesn't really sound like a problem though.
Mine does that too. The potentiometer is seated inside the device little bit freely, being hold in place by the main PCB. It can move around a little bit.Does anyone else get a rattling sound from the volume wheel when you shake the UP5? If I hold down the volume wheel button I don't get the rattle or it's much less. It's probably not a big deal but want to see if it's common.
kodered
Hi guys, had a search in the thread and couldn’t find anything on it.
Is there any latency/delay issues when in bluetooth mode watching videos on iPad/iPhone?
Thanks
Thanks
fish1050
I have been trying to decide if I should upgrade my Q1 to an M3X when I stumbled across the UP5. The DAC/Amp chip and implementation seems to be the same as the M3X offering the same SE single/dual dac options. Can I use the Q1 via USB-C to the UP5 or am I limited to bluetooth?No, UP5 do not output data through USB output.
How does the UP5 compare to the M3X sound wise considering the same dual ES9219C implementation? I love the idea of the M3X but the UP5 gets me closer to the M3X without having to deal with android and at a much lower cost. Traveling the better sound quality of the M3X would be lost and the Q1 would be fine and more portable. I would be looking to use the UP5 at home and as a transportable option. I see that you lose battery life with the UP5 compared to the M3X but still pretty good at 15 hours single ended.
Would I notice an upgrade in sound quality vs the Q1 alone? Any feedback would be appreciated.
fish1050
Canada now has an official Shanling dealer that sells some of their DAP's including the M3X and the UP5. Layton Audio in Montreal was confirmed by @Shanling to be an official dealer in the M3X thread and ASONA the Canadian distributor will cover warranty issues.My UP5 just landed and I love it. Came out of the box with latest firmware. Currently driving my EJ07M on Low Gain with volume at only 15 and it sounds amazing. I'm very happy with this device and the UP2 is now hardwired into my car.
Total: 8 (members: 0, guests: 8)
