Hey
@Shanling thanks for replying.
Well, I'd say it's random though it's hard to say there is a pattern to it. The UP4 worked as it should last week, but now it's failing to power up no matter I reset it. It's not the first time it happens: a while ago, suddenly it just wouldn't power up, until one day it did unexpectedly. Then it would only power up after a reset or full charge. Then it worked fine. Now it doesn't work.
When it powers up again, all I'm certain about is this:
a) if I listen the "power off" message when I press the button, it will power back on.
b) now, eventually, I will push the button to power off, a long beep will sound, followed by yellow steady light and then a red light to power off. If that happens, there won't be a "power off" message and then it won't power up.
If option b) happens then it will need a reset or not even power up at all until one day, it will.
It's very annoying since it is supposed to be a portable DAC, but you never tell if it'll work whenever you need it. So, it's just a brick in my pocket most of the time.
If I plug it in to reset, first, it will show a yellow or cyan steady light. Then it will show a red light and then it will set to pairing mode. I really don't know why sometimes it shows yellow and any other time it will show cyan. There too many color light codes in this device.
As for the firmware version, it is the latest: 1.3.2
