Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Oct 8, 2021 at 9:16 PM Post #1,306 of 1,466
Here's another observation @Shanling and all... When I manually power on the UP2, it auto connects to my phone or last paired device. With Car Mode when I power comes in through the USB Cable / Charger, indeed it automatically powers up but it no longer auto connects to last device ..... it would be great to fix that.
Oct 8, 2021 at 9:38 PM Post #1,307 of 1,466
the app is showing my UP2 as having Firmware 1.8.6
Same here but on shanling controller app and no car mode there, never been successfull in actually running eddict player.
Btw, if it wouldnt it be too inconvenient for you, could you check your UP2 for static at low frequencies? You can refer to this post . LDAC sample rate can be changed in Developer options on Android.
@Shanling
Does Eddict player reqire something to be turned on for it to run correctly? I have it crashing on start on 3 Android phones. 1 is stock Android 9 and the other 2 are with custom roms Android 10 and 11.
Oct 8, 2021 at 11:00 PM Post #1,308 of 1,466
Downloaded, upgraded and see "Car Mode" in the Eddict App! Yeay! I've been wanting this..... but interestingly, the app is showing my UP2 as having Firmware 1.8.6 ... hmmm? Anyway, happy to have Car Mode. Now I can get rid of my BTR3 in the Car and get and UP5 for the Gym, when Cycling and to walk around with. Thanks
Just some stupid mistake in naming, you can ignore it.
Will check on this.
@Shanling
Will try to test this out. If I might ask, why do you adjust it to 44 instead of default 96?
It's normal app, doesn't demand anything extra. Can you please tell me what phones and what version of app you are running?
Oct 8, 2021 at 11:12 PM Post #1,309 of 1,466
Great, looking forward to your result. Have the older version UP2 that cant update OTA, so probably best to test on that one for consistency.
I use 44 since my music is 44 and im avoiding upsampling, also better battery runtime with 44. Also use it on Linux, which defaults LDAC at 48Khz, on which the problem is also there.
Edit: Also worth adding is that 44KHz uses lower bandwidth (909kbps vs 990kbps at 96KHz) so some small stability improvement of the link is probably also there.
Its 2 old phones, Nexus 4 and Nexus 5, and a newer Samsung Galaxy A10. Only thing all those phones have in common is that they all have arm32 cpu's(32 bit). Maybe the app has problem with that and made for arm64(64 bit)?
Oct 10, 2021 at 8:26 AM Post #1,310 of 1,466
Firmware Update for UP4, UP2 and MW200.
Adding in-vehicle mode to UP2 & UP4.
https://en.shanling.com/article-UP2UP4MW200Update.html
Looks like the whole website is down:
Oct 11, 2021 at 10:33 AM Post #1,314 of 1,466
Both my UP2 and UP4 show up as 1.8.6 - very confusing, as it's incorrect for both of them.
I'm guessing not much testing went on before releasing this firmware...
Oct 11, 2021 at 9:52 PM Post #1,317 of 1,466
@Shanling Download pages of UP2 and UP4 are not up to date.
They always get updated later, news section is always the main place to receive updates first.
Eddict Player app - Dasnt work with Realme 7PRO :/
Now i try it on Samsung Galaxy S7 and this app also is broken: https://play.google.com/store/apps/details?id=com.shanling.eddictplayer
How can i turn Vechicle Mode ON ? :D
Please what exact issue are you facing?
Oct 11, 2021 at 10:03 PM Post #1,318 of 1,466
Oct 12, 2021 at 4:38 AM Post #1,320 of 1,466
On Samsung i have info about app broken.
On Realne i have no info. Or if i open it few times i have info that its not working and i allready try it start.
Realne 7PRO
Seems there is some issue on version in Play Store, we are sending in new version to fix this.
