I think it means your battery is already charged.Just purchased a Shanling up2 from aliexpress.
Works fine with phone and pc via usb, but when i plug to charge no red light appears.
Ive tried with multiple chargers with differents Ma, but nothing happens? Any ideas?
Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
- Thread starter Shanling
PROblemdetected
Previously known as sakt1moko
Mmmmm it comes already charged? A little bit strange I think.I think it means your battery is already charged.
I read that u need a 0.5ma charger, but even on the usb portnof the pc no light appears...
Mine had a near full charge when I got it. If I were you I would just use it for an hour or two and then see what happens when you plug it in after that.Mmmmm it comes already charged? A little bit strange I think.
PROblemdetected
Yeah mate, u're right, after use for 2 hours I pluged and finally the red light appears!Mine had a near full charge when I got it. If I were you I would just use it for an hour or two and then see what happens when you plug it in after that.
Btw, anyone knows a ldac transmitter for pc?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
jbattermann
- Sep 12, 2016
Shanling M0/M2x/M5s![]()
So just to clarify: the UP2 cannot transmit aptx-hd or ldac, it's merely a receiver?
Could I use the M0 as a dac for an iPhone and have the m0 'forward'/transmit the iphone's audio signal via aptx-hd or ldac?
Yes, UP2 is only receiver. It was never presented as transmitter.
With iPhone, not sure how is current state of iOS and its possibility to output over USB digital to USB DACs.
PROblemdetected
Can be pluged to the pc and use like a bluetooth?Shanling M0/M2x/M5s![]()
Btw, im using right now UP2 as soundcard on the pc, just amazing how it sounds.
It will be amazing if the drivers let use it like a 7.1 soundcard, it will be best portable soundcard for pc
Yes, all our current player can work as Bluetooth transmitter. Adding LDAC bluetooth to any computer.
When UP4 is going to be released?
And price range?
And price range?
PROblemdetected
Im gonna send back the UP2 and get a M0Yes, all our current player can work as Bluetooth transmitter. Adding LDAC bluetooth to any computer.
But I doubt about some bluetooth stuff, could u explain it more, because I dont get some ideas seeing the info of the product.
1. Its works like a trnasmitter, in all formats (apt, ldac, aptx ll...) But when is a receiver, it only works on LDAC and SBC?
2.It can be pluged on the pc like UP2 and used likena soundcard?
3.Its got the same DAC like UP2, right?
Thanks!
1. I don't kno wIm gonna send back the UP2 and get a M0
Thanks!
2 and 3, if you read the specifications it is explained there, yes, they have the same DAC and if it can be used as a DAC USB only by connecting it via a cable to the computer.
What would be the point of returning the Up2 and buying the M0? They are practically the same devices.
PROblemdetected
1. I don't kno w
The M0 is a trnasmitter as well, so I could use my pc like source.
For 30bucks more u get a standalone player as well
PROblemdetected
Some problems with UP2. It didnt work from 2 meters away from the phone, no walls. Anyone got this problem? No matters what codec I choose, If I put myself between the shanling and the phone, the music just stops
Phone: xiaomi mix 18k, I used with some cheap earbuds and never have this problem. Firmware updated
EDIT: tested with my laptop, same isues, when i change of room loses conectivity, its normal?
Sorry...
Total: 8 (members: 0, guests: 8)
