Shanling UP4 & UP2 - Bluetooth 5.0 DAC/AMP with ES9218P, balanced output, supporting LDAC, HWA LHDC, aptX HD, aptX Low Latency, aptX and AAC.
Oct 1, 2019 at 4:27 PM Post #376 of 1,466
Haiii for All Shanling Teams ... ☺ I just bought the "Shanling Up2" product, which is still on its way ... And there's something I want to ask first ... :
~ Is USB DAC Type-C included as a wireless line connectivity (alternative path besides the 3.5mm plug hole) ???
~ When the 24-bit Shanling Up2 USB DAC Type-C, combined with a dongle cable from iBasso DC02 32-bit 3.5mm, Hidizs Sonata II 24-bit + IFi Earbuddy, Shure SE215 Earphone + Enhanced Fully Adjust High Premium cable with Hebra Definition cable (I have) & The device that I use is Xiaomi Pocophone F1 ... Will Shanling Up2 becomes a wireless line that will be read 24-bit or 32-bit from some additional combinations of cable / fixed in the wireless line (Hope you can understand what I mean ) ???
~ Is Shanling Up2, will release additional Leather Case or Silicon Case accessories like the previous Shanling M0 heir ???
(And a little positive feedback from me personally & broadly + in detail, when releasing additional Case Leather or Case Silicon accessories, add a case clip to the back of the Case Leather or Case Silicon accessories, so it doesn't have the plain shape of a Leather Case or Silicon Case accessory (for example Silicon in BTR3), an earlier version, which can also be linked together in shirts or pants for Leather Cases or Silicon Cases to anticipate cuts from various types of collision aspects, from accidental / accidental falls, slams and blisters from unwanted friction ... (To be honest this is my opinion that is almost different, very, very rarely people object as much detail as I mean)) ... ✌
Using my initiative personally when looking at the first item, which made me fall in love at first sight at Shanling Up2 as practical as possible for the portable receiver class into a unit package that suits my desires & needs personally ... Hopefully this can be carried out by positive input me, which seems strange & of course makes sense ... Thank you very much to Tim Shanling, without the slightest exception from me & happy to know everyone Guys ...
Oct 1, 2019 at 4:35 PM Post #377 of 1,466
Some problems with UP2. It didnt work from 2 meters away from the phone, no walls. Anyone got this problem? No matters what codec I choose, If I put myself between the shanling and the phone, the music just stops
Phone: xiaomi mix 18k, I used with some cheap earbuds and never have this problem. Firmware updated
EDIT: tested with my laptop, same isues, when i change of room loses conectivity, its normal?
0 problems
Oct 1, 2019 at 10:34 PM Post #378 of 1,466
Haiii untuk Semua Tim Shanling ... ☺
Saya baru saja membeli produk "Shanling Up2", yang masih dalam perjalanan ... Dan ada sesuatu yang ingin saya tanyakan terlebih dahulu ...:
~ Apakah USB DAC Type-C termasuk sebagai konektivitas jalur nirkabel (jalur alternatif selain lubang colokan 3.5mm) ???
~ Ketika 24-bit Shanling Up2 USB DAC Type-C, dikombinasikan dengan kabel dongle dari iBasso DC02 32-bit 3.5mm, Hidizs Sonata II 24-bit + Earbuddy IFi, Earphone Shure SE215 + Peningkatan Penuh Sesuaikan kabel Premium Tinggi dengan kabel Definisi Hebra (saya punya) & The perangkat yang saya gunakan adalah Xiaomi Pocophone F1 ... Will Shanling Up2 menjadi jalur nirkabel yang akan dibaca 24-bit atau 32-bit dari beberapa kombinasi tambahan kabel / tetap di jalur nirkabel (Semoga Anda bisa mengerti maksud saya ) ???
~ Apakah Shanling Up2, akan merilis aksesoris Leather Case atau Silicon Case tambahan seperti pewaris Shanling M0 sebelumnya ???
(Dan sedikit masukan positif dari saya secara pribadi & luas + terperinci, ketika merilis aksesoris Case Kulit atau Case Silicon tambahan, tambahkan case clip ke bagian belakang aksesoris Case Kulit atau Case Silicon, sehingga tidak memiliki bentuk polos seperti pada aksesori Leather Case atau Silicon Case (misalnya Silicon di BTR3), versi sebelumnya, yang juga dapat dihubungkan bersama dalam kemeja atau celana untuk Leather Case atau Case Silikon untuk mengantisipasi pemotongan dari berbagai jenis aspek tabrakan, dari kecelakaan / jatuh secara tidak sengaja, membanting dan lecet dari gesekan yang tidak diinginkan ... (Jujur ini adalah pendapat saya yang hampir berbeda, sangat, sangat jarang orang keberatan sedetail yang saya maksud)) ... ✌
Menggunakan inisiatif saya secara pribadi ketika melihat item pertama, yang membuat saya jatuh cinta pada pandangan pertama di Shanling Up2 sepraktis mungkin untuk kelas penerima portabel ke dalam satu paket unit yang sesuai dengan hasrat & kebutuhan saya secara pribadi ... Semoga bisa dilaksanakan oleh masukan positif saya, yang tampaknya aneh & tentu saja masuk akal ... Terima kasih banyak untuk Tim Shanling, tanpa pengecualian sedikitpun dari saya & senang mengetahui semua orang Guys ...
The USB DAC function is limited to 16bits / 48kbps, I don't really notice a different one between bluetooth and usb, for me they sound just as good.
On leather cases, I do not understand why they have not done so.
Oct 2, 2019 at 12:36 AM Post #379 of 1,466
Thank you for the answer, My friend ... ☺
I really hope that the Shanling teams can immediately release a special leather for UP2 ... It is very unfortunate if there is no choice of leather or silicon (which combined into one unit of leather case / silicon case between the combination with a clip case with a premium leather clip case / silicon clip case in one package) very interesting things when implemented in full are really real ...
(A simple example of that picture, the combination of leather with a clip case when wrapped in color stitching black / color stitching in accordance with the color of leather, will look synergic to each other) ... Hopefully their team can realize it enter positive I am Guys ...
Oct 5, 2019 at 11:03 PM Post #381 of 1,466
When UP4 is going to be released?
And price range?
November/December?
Priced comparable to its rivals.
Im gonna send back the UP2 and get a M0
But I doubt about some bluetooth stuff, could u explain it more, because I dont get some ideas seeing the info of the product.
1. Its works like a trnasmitter, in all formats (apt, ldac, aptx ll...) But when is a receiver, it only works on LDAC and SBC?
2.It can be pluged on the pc like UP2 and used likena soundcard?
3.Its got the same DAC like UP2, right?
Thanks!
As transmitter, it does SBC, AAC, aptX and LDAC.
As receiver it does SBC, AAC and LDAC. Difference being only the aptX.
Yes, it works with computers as USB DAC or as USB Bluetooth transmitter.
Yes, same ES9218p DAC/AMP chip.
Body is very strong insulator of BT signal, but there should be other reflections of BT signal from surrounding. It could possibly show such problems only if you were in open field.
- UP2 can works as USB DAC when connected to computer. There is no output through USB-C connector(digital or analog).
- USB DAC on UP2 is limited to 16/48. But LDAC and LHDC are supporting Hi-Res over Bluetooth.
- Not sure about possible plans on leather case for UP2.
Is anyone else have the issue that the UP2 will only play SBC from an iPhone or iOS devices?
Are you sure your iPhone is doing just SBC? As SBC uses blue and AAC cyan color of LED( I know, kind of dumb decision to have it this way), I know some new users were just confused by this.
Oct 6, 2019 at 7:26 AM Post #382 of 1,466
If I may ask, why aren't you interested / not sure enough to implement a collection of leather or silicone for UP ???
It is very unfortunate if there is no companion for an accessory for UP2 ... Whereas your competitor UBTR3 applies, which precisely the specifications of the level class (won a lot) dominate more to UP2 ... Are you less interested in implementing leather or silicone, because it is only limited to the receiver, unlike the portable M0 which only has a minus in hardware (BT V4.0) ???
Will in the future release a portable successor M0 with the same specifications, or higher + as an improvement in terms of hardware (M0 next generation BT V5.0) or the successor to the UP2 to UP3 receiver with 768kHz / 32-bit version ???
Oct 7, 2019 at 9:42 PM Post #383 of 1,466
Anything is possible regards some additional case, will see.
When we update M0, it will likely have newer Bluetooth chip.
Currently there is no Bluetooth codec supporting 32/768 kHz. Even the current support of 24 bit is quite demanding to achieve proper connection.
Oct 8, 2019 at 9:10 PM Post #385 of 1,466
How are people enjoying this? Still something worth investing in?
Love my UP2 - Use it everyday as BT receiver out and about and as USB DAC in the office. You'd have to pry it out of my cold dead hands.
Noticeably better sounding than the BTR3 IMO - the UP4 looks very interesting but I'm happy enough with the UP2 that I don't think I'll upgrade until I need to.
Oct 9, 2019 at 3:04 AM Post #388 of 1,466
@Shanling Hello, a query when in USB DAC mode with the notebook (W10), how do I know if it is processing at its highest quality? That would be 16 bits at 48kbps.
UP2 itself has no indication which bit/kHz are currently played. You need to check your files and settings of your playback software.
Oct 9, 2019 at 8:50 PM Post #390 of 1,466
Hello,
Is it safe to apply the firmware update in a Windows virtual machine ?
Not sure, that software is from Qualcomm, not ours.
