Shanling MTW100 - True Wireless IEMs, IPX7, BT5.0 Balanced armature or Dynamic driver
Jul 7, 2019 at 10:43 PM Thread Starter Post #1 of 220
Shenzhen, China
Introducing Shanling MTW100 - True Wireless IEMs
Available in two versions
- White version using 6mm Dynamic driver with graphene diaphragm
- Red or black version using single full range balanced armature driver from Knowles.
Bluetooth 5.0, supporting AAC and SBC codec.
Balanced Armature version – Up to 7 hours on single charge, up to 24 hours with charging case.
Dynamic Driver version – Up to 6 hours on single charge, up to 21 hours with charging case.
Touch sensor for control over calls and playback (play/pause, previous, next).
Surrounding awareness mode, for moments when you need to hear world around you.
IPX7 waterproof earphones.
Mono mode available for both left and right earphone.
Charging either with USB-C cable or wireless charger.
Jul 15, 2019 at 11:47 PM Post #10 of 220
Sorry about this, had some problems with getting it posted on Head-Fi, had only phone with me in Korea.
Three key information:
- These will be available both with dynamic and balanced armature, they have quite significantly different tuning.
- AAC and SBC support only for this model.
- Price is not finalized yet, but these should be in the more affordable part of TWS market(<100$).
Jul 18, 2019 at 4:02 AM Post #11 of 220
More information on our MTW100
Jul 18, 2019 at 5:44 AM Post #12 of 220
does it have apps and can it be firmware updated?
Jul 18, 2019 at 6:02 AM Post #13 of 220
Damn, both of those models look sweet!
I love you guys use the MMCX connectors, and not the awful KZ connectors most use nowadays.
They share the same shell, right?
Why not stick with the same 10mm driver? (thats actually a doubt I have with most TWS earphones as 10mm seems pretty standard for IEMs today but TWS has 6mm as standard and sometimes 8mm)
Space constraints?
Does that mean we shouldn't expect a hybrid version anytime soon?
Jul 18, 2019 at 9:17 PM Post #14 of 220
Not sure about the app. We are developing our app for our players and UP2, but I think so far there are no plans to include any functions for IEMs.
Space constraints?
Both models of MTW100 are identical apart from the driver ( and then acoustic filter in nozzle).
Our 10mm driver we use in our IEMs would be too big for shell of MTW. 10mm driver would need to sit further from the nozzle, making IEMs much bigger and pushing weight of it further away from ear, resulting in less firm fit and Frankenstein look.
Same goes for hybrid version, it can be done, but you would end up with quite massive IEMs.
Jul 18, 2019 at 10:23 PM Post #15 of 220
Wonder how the voice call quality is with these wireless IEMs.....
