Shanling M3
Aug 22, 2015 at 2:57 AM Post #152 of 567
I am so happy that I own it, it is optical out is exceptionally good paired to my HUGO. I will not comment anymore on the sound till the honeymoon period is over. I truly like the UI, simple and effective.
I think it is safer to say I will be getting the M2 if it is the same part and sound as M3. Only if there was a way for me to fit in a pair of OPA627 inside this.
Aug 22, 2015 at 3:03 AM Post #153 of 567
Glad you're digging the UI. I thought it was really easy to get the hang of and quite effective. Can't wait to see what UI lessons they've learned that'll show up in the M2!
Aug 22, 2015 at 3:55 AM Post #154 of 567
What kind of DSD file will the M3 accept? I have seen picture of people playing DSD files but I cant seem to let it work for me. Firmware is 2.0.
Aug 22, 2015 at 12:28 PM Post #158 of 567
I want to open this see if I can change the ad8610 to opa627, I can't seem to do so, is there a third screw somewhere?
If love to help, but the M3 I reviewed is out on tour - letting other headfi'ers check it out. Hopefully one of the other M3 owners will chime in soon. You could always PM Shanling.
Just a thought - maybe it's glued together. I just saw pics of s Fiio X5 tear down, and after all the screws were removed there was glue holding it together. The guy had to pry it apart. He tried to be careful but ended up tweaking some of the internals.
Anyways, I look forward to hearing more about your exploits trying to mod your M3. I've got OPA627 in my E12 DIY amp right now and can see the appeal.
:beerchug:
Aug 23, 2015 at 1:24 AM Post #160 of 567
Here is my wish, I would love for M3 to sound a little smooth. In large this sounds like C4 with much improved bass.
What do you need to be smoother? I found it quite smooth but remember reading a review where they commented they'd prefer less energy up top. That wasn't my experience, though.
Aug 23, 2015 at 1:55 AM Post #161 of 567
Coming from things like ak120 and 627x I sort of have a different precpetion of what is neutral and smooth sound is.
In large M3 is the best bang for a buck dap that I own. Optical out works and so does the raw power. If I ever amp it it wouldn't not because it lacks power but because I want to change the sound.
Aug 23, 2015 at 1:58 AM Post #162 of 567
Gotcha. I'm coming from DX90 and X5 and found M3 to be a smoother sounding DAP than I'm used to. I've gotten similar comments from others who've used it.
Aug 23, 2015 at 9:39 PM Post #165 of 567
M3 accepts up to DSD128, in the format of .DSF and .DFF
But you must update to 2.10
