alex5908
Thank you very much for trying to help me out.
How shall I remove the middle part of the wheel? There's only one screw and I removed it. Still the cover is in place.
Considering that Shanling representative is responding to you right here, yes, we will try to help you.
I was talking about removing wheel, since when you remove wheel(middle part of it), you will get clear look on the button mechanism.
Button itself is small gold "bubble", that when pressed records it as command. If this button doesn't work, it was probably damaged and pretty much need to be replaced on PCB.
