zeusminos
- Feb 8, 2016
First of all thank you @HiFiChris for your reply. I am mainly use my V-MODA Crossfade wireless and other 32ohms headphones.
Yep, the M2 would act as DAC and Amp (including volume control), but the playback would have to be controlled with the smartphone.
What headphones are you intending to use?
Imvho, the M2's Amp section lacks some dynamics and transparency when used with better in-ears (no multi-driver ones because of the output impedance, I'm speaking of singly dynamic driver stuff with flat impedance response like the IE 800), wherefore when used with IEMs, I find it to open up more when used with an external Amp over the Line Out (when testing, I properly volume-matched the amp on the LO vs. the headphone out). With full-sized headphones however, it sounds dynamic, transparent and powerful directly out of the headphone output (trust me, the M2 is very powerful).
When used with in-ears, I personally find the M2 to perform better with an amp that bypasses the internal amp.
