Donut
- Feb 24, 2005
So which one isolates better?
Originally Posted by Nak Man I was about to say hd25, IF you have good seal on your ears. They sit closer to ear canal so probably isolates more effectively. I'm a bit lazy to compare them now but there's a good measurement: http://graphs.headphone.com/graphCom...Type=2&graphID[]=189&graphID[]=213 |
Originally Posted by Donut So it sounds like the 25s are the better overall headphones, but the 280s are the value pick. Since I'm trying to decide between these two (I considered the Beyer 831s before I took them out of the running), if I can afford it (which I'm fairly certain I can), is it worth it to spend the extra dough for the 25s (considering I'd be using them as portable phones)? Edit: I'd be using it mainly out of my iRiver flash mp3 player and also occasionally out of my computer, and was wondering if it was worth it for me to spend approxmiately $100 more for the 25s (generally speaking)? |
Originally Posted by Donut turtle beach santa cruz sound card, variable bitrate (at least 192), use both foobar and wmp, typically use lame...i typically use the headphone jack out of my speakers (logitech z-5300s), but i can hook them up directly to the sound card... |
