Tuneslover
First observation:
Seem fine for current hit songs and not doing bad for Florence and the Machine.
I reach back to a long-time favourite called Great Gig in the Sky by Pink Floyd. ALAC file.
The vocals are recessed to the point where I have to concentrate to hear them? The rest of the music is nice and loud but the vocals sound like they're playing in another room?
I flip over to the Grado's and it sounds wonderful.
I know it's WAY too early to judge and it took me a few months to like my Grado's, but if the vocals aren't front and centre in a piece that is all about the vocals, what's the point??
Back to listening.
Shane D
I purchased a stock replacement Sennheiser HD 600/650 SE cable last year and never bothered using it until yesterday when my HD6XX arrived. I prefer the longer stock cable with the 1/4" plug over the cable that came with the HD6XX so I decided that I would use it instead. I'll run in both the HD6XX and the stock replacement cable at the same time.
Today I have been sneaking brief listens as I run in my HD6XX and doing quick comparisons with my HD650's. It's still too early to do any serious comparisons but the HD6XX sound ever so slightly clearer in the high frequencies but the bass seems a tad lighter but also tighter. By comparison the HD650 sounds slightly warmer overall.
I don't have a large (aka...fat) head so I never really understood the clamping complaints that many head-fiers have reported, however the HD6XX is definitely tighter fitting than my 3-4 year old HD650. Upon closer examination it appears that my ear pads have flattened out a tiny bit. Also the openings are perfect on my 650's but the pads on the 6XX are a bit more confining. Maybe I need to think about replacing my old ear pads. Funny how over time they do flatten out, even for people that have slimmer melons.
There is no mistaking that the HD6XX sounds very very close to the HD650. It's only my ability to quick swap the headphones (my Lake People G109S has 2 headphone outputs) that allows me to detect any differences. I'll check more closely later next week.
The HD650/6XX has an entirely different sound signature from the Grado's. I suspect you are very accustomed to the Grado sound and most likely find the Sennheiser sound very different from what you're used to. My suggestion to you is to put your Grado's away for a while and allow your brain to adjust to the Sennheiser sound. In time you will really appreciate the HD6XX.
