sup27606
- Aug 9, 2016
What would you recomend as a improvement to the e12? A amp/dac combo? I have been eying thr oppo ha 2 and the new schiit fulla 2 but i dont know if those would make my hd600 and dt770 80ohm better. I get a similar response to yours when using the e12. I get more volume but thats pretty much it. Maybe the sound gets a little tighter and cleaner on the dt770 but we are talking about really marginal stuff. I mostly use portable sources like my air 2. Very rarely use my conputer ad my listening source.... So if upgrading i would like something more geared towards portable sources....
I am myself looking for a suitable portable solution to use with the 6xx, but I think I am looking in vain. Maybe there isn't any, at least not at the price point we are considering. If I have to spend north of $500, I would rather spend it on a desktop amp. For now, I tend to resonate with whoever is saying, 6xx is not meant for portable use. For example, the Cayin C5 gives excellent micro detail and imaging with my lower impedance headphones and IEMs, but none of that is sensed with the 6xx. This means, there's simply not enough power, and C5 is one of the most powerful portable amps.
BTW, compared to C5, I get much better sound through the pono player using the balanced connection, and this is my portable solution for now. That's why I recommended looking for balanced portable amps, which will deliver more power to the 6xx compared to unbalanced and could be a viable solution.
As for the desktop, I saw good reviews on the cheap $50 Nobsound Ns-08e. So I bit the bullet and got one. I also swapped the tubes to the recommended Amperex 6688. It sounds surprisingly good with the 6xx. I can immediately engage with the music, and my wife also agrees.
I would tread carefully about desktop amps, as I have read they are picky in that respect. So high end may not necessarily mean good. For now, I am targeting the jotunheim, may be in six months.
