bigshot
Headphones should be compared to *known sound*, not each other. The ideal would be to compare to a live source. Anyone who has attended a number of chamber music or orchestral concerts is very familiar with what a real quartet or orchestra sounds like. Since the sound is not amped or processed in any way, it's a fair reference. If you aren't familiar with the sound of acoustic instruments, a high quality set of reference speakers will have to suffice.
Ohhh... kayyy...
Here is what you do... Set up a listening position in the optimal listening position in front of your speakers. Place your preamp there, so you can quickly switch from speakers to phones and vice versa. Patch in a graphic or parametric equalizer to the headphone amp only... leave the speakers flat.
Adjust the volume of your headphone amp and the speakers to a relatively quiet listening level. It's absolutely vital that the volume level be exactly the same. Do an A/B comparison, balance matching your cans by adjusting the equalization band by band until they appear to precisely match. Make a note of the EQ offset for each frequency. Do the dynamics (loud to soft) sound the same between the two?
Then turn the volume up to the maximum listening level and do the same. I guarantee you that the EQ offset isn't the same at the different volume levels. Do this with several sets of cans and compare the offset numbers for each.
I've done this, and I've also done even more detailed tests involving precisely equalizing a recording using cans and then playing it back on a variety of speakers from boom box all the way up to high end systems. I found that many cans have humps and dips in the frequency response, particularly in the bass and high mids. (Ranges that can fool the ear into thinking sound is "better" when it is actually more imbalanced...) These inbalances became immediately apparent when I played back the equalized recording through a variety of speakers.
For instance, one set of cans had a pronounced high midrange boost. This inaccuracy caused me to cut the midrange too far when I was EQing. When I played back the recording on a variety of stereos, it sounded extremely muffled. Other cans tended to swallow the bass at loud volumes. This caused me to equalize the recording in a way that made it sound boomy on speakers.
These are relatively precise ways of analyzing the response of headphones.
Yes you can... Which of these aspects do you hear as part of the veil?
Perception of distance involves...
1) Reduction of overall volume
2) Reduction of bass and treble
3) Alteration of the directionality of the sound
4) Increased reverberation and reflection off of the room walls
5) Reduction of the difference between left and right ears
6) Reduction of dynamic range
Perception of muffled sound involves...
2) Reduction of treble and mids
4) Reduced reverberation
5) Smearing of transients
If you can pinpoint the effect the veil is having on the sound in more precise ways, we can analyze it and try to figure out what you're hearing.
See ya
Steve
Originally Posted by markl This argument makes no sense at all. You want to argue that comparing headphones *isn't* valid? |
Originally Posted by markl I'll type slow so you can follow... |
Ohhh... kayyy...
Originally Posted by markl OK, let's talk speakers first. I have some very good speakers in my system right now. I've had numerous speakers from $200-$2500 per pair at various times in my rig in the last 20 years. The veiling isn't there on the speakers, it's only there on the Senns. |
Originally Posted by markl It's the difference between looking out at the backyard through a foggy window pane and no window at all. It's a veiling and hazy-ness that happens throughout the entire presentation... Also, this isn't about frequency response, as I've said consistently... I don't know how to make it any more clear to you. |
See ya
Steve
