Sewer Guy
I do not have any molds to show you; the last castig I did was an O scale model rairoad car body (eight years ago). It was cast in 4 pieces 2 sides & 2 ends.
The mold poses no problem though. I would simply make a mold of a Senn. plug with the proper RTV, in a small box. Next cut the mold in half so it is a 2 piece mold. Install two alignment pins in one half & make holes to receive them in the other half.
Take the pins w wires soldered to them & lay them in the mold & join the two halves of the mold; then pour in the prepared mix & let it sit until fully hard & remove the mold. You now have plugs that will fit the Sennhiser 580, 585, 600, 650. A proper plastic strain relief would need to be installed on the wire prior to pouring the mix; this would produce a professionally finished plug.
During the day I am in the R & D dept. of a manufacturer of TV inspection equipment; it is not necessary to do detailed drafting for the plugs unless you want a record of the dimensions.
I am willing to cast some plugs if somone will: A. provide me with the contact information for the source of the pins, or B. send me some pins to make some test castings with.
Waiting to hear.
Waiting to hear.
