streetdragon
- Dec 29, 2011
The question is, with the eventual decrease in friction, will they slide around while on your head? The way they sit on the head, I don't see this happening. If they don't slide around while you're wearing them, then it really shouldn't matter.
They shouldn't be that loose until they slide while you wear them. I don't have momentums but even a hd202 that is very worn out won't slide when you are actually wearing them, their earcups however do fall to their lowest position when you put them around your neck and walk around. (the constant clamping pressure of wearing them should add more friction to keep them in place.)
