KimLaroux
- Aug 2, 2011
Well that's sad.
I own a Motorola Moto G with Android 5.1
The stock, apple certified cable only allows for play and pause. I cant take call or hang up using the remote, and the microphone does not work. Volume up and down does not work either.
So I bought the RCG M2 cable from Sennheiser. This is an alternative cable, made by Sennheiser, for Android devices.
With the RCG M2, only the microphone works. I can't play and pause. The volume does not work. I can't take call or hang up.
Any of you have different experiences with these cables, using different phones? At this point I'm considering either throwing my hands up and buying and iPhone. The RCG M2 says it's designed for Samsung Galaxy phones, so that would be my next option. Though I'd like to try the remote with a Galaxy before buying one.
