0rangutan
- Jan 4, 2011
Thanks Duncan.
So the pairs going for £70-80 on eBay are a safe bet for an IE800 fan?
Yeah if im not satisfied with MDR-7550, im going to get IE800.
I know for fact im not even going to bother looking on Ebay to buy IEM now..
they're £75 in Argos (seeing that you're quoting in GBP), so a safer bet if you're worried about fakesThanks Duncan.
man i have to give it to ie800, you know i had my share of iems, and whenever i plug in the ie800 it simply makes me smile, its a dam great iem
what i did i bought the silicon foam filled tips from trinity audio and they fit without popping out like other tips
and now i am in a bliss of audio
yes i have the zeus R which is my number 1 iem but immediatley after it comes the ie800
i had mine on the sale forum but i will remove it from there as this is a dam good iem and is a keeper especially after buying the trinity audio tips
Linky for tips?
CP100
http://www.head-fi.org/t/816318/trinity-kombi-tips
the strange thing is i ordered both large and medium, the medium does not pop out while the large one does
I use the 200 TSX and those work pretty well but be carefull when getting them out of your ears again, as it is possible the foam remain in your ear(s). Did anyone try the T100?How do the comply tips affect the sq of the ie800?
The early batches of IE800 seemed to show microphonic/cable-noise. Has the issue been corrected later with a better stock cable? Has any recent buyer faced a similar issue?
