Sennheiser IE800 IEM's
- Thread starter PhilW
- Tags
- sennheiser-ie800
deltronzero
- Jul 8, 2014
Got to agree, except for the integrated screen the pads are not all that different from the Momentum in-ear tips I ordered direct from Sennheiser, believe they cost me $11.99 Canadian for a quantity of 10”.
So I’ve no problem recommending these ie800 copies from China...I have some for backup, they fit just fine like the OEMs and only $9.99 US plus free shipping.
http://www.aliexpress.com just search for ie800 tips.
I have these...they suck. Nowhere near the original tips. The problem I have is I only lost one of them...so it sounds kinda weird with a fake tip on one side and OEM the other.
Rob80b
Except for the visual seam the ones I have are pretty close to the originals....problem with copies from China it's always the luck of the draw...hit or miss....still $40 for an OEM replacement pair...does suck...especially when you only need one..... : (
Jd007
- Jun 22, 2010
Less than 2 month old IE800, today the right earpiece stopped working. Tried on multiple devices, only the left piece makes sound, right side is dead silent. Anyone else experienced this issue? There has been no damage to the cable or earpieces, I took good care of the headphones.
How did you store the in-ears? In the included case? Was stress put on the 3.5 mm connector when listening?
You shouldn't put your DAP into a tight pocket, especially when walking, when the in-ears are still connected.
Anyway, as you've still got warranty, you should contact the store you bought the IE 800 from.
Jd007
- Jun 22, 2010
I am always careful with not putting stress on any cable connection, including the 3.5mm connector and the earpiece connectors. I have a dedicated pouch in my backpack to store my headphones
i bought it on amazon (fulfilled by amazon merchant), hopefully they will honor the warranty
Dobrescu George
Reviewer: AudiophileHeaven
Get the warranty!
A quick advice is to be careful of driver flex. It is best for ie800 to not be flexed too much, slow insertion, take them out slowly, and you should be good.
Shure or bust
- Jul 24, 2015
- Oct 8, 2010
My IE800 has been a tank, it has survived 2 partial recable and now total recable, never a single problem. The sound from the total recable is a welcome change, it reduces the V shaped tendency and give more meat to the overall sound. I'll probably never sell it along with my T8ie Mk2, they are like brothers.
Sorry to hear this but yes, please do get in touch with the dealer.
Stay updated on Sennheiser at their sponsor profile on Head-Fi.
Jd007
- Jun 22, 2010
Talked with Amazon customer support, and I have initiated a return process directly with Amazon which was super easy. Guess it's back to the IE80s (had them for years never a single issue) for me, at least for now. Thanks for all the info guys. But damn miss the IE800 sound already, IE80s are not even close...
Andreeas1978
Previously known as "AndreiNicolae"
Hello friends, I am planning to make a big financiar effort to buy myself the ie800. It will be from an official retailer, but I suspect they don't have the latest serial no in stock, not many buy that here. My question is since what serial numbers things have changed with cable problems? How low can the serial no be to keep it relatively safe? I also have a pair of HD800, very early serials and.. very aggressive spike in freq. Is the ie800 serial on the box to check it from outside? Thank you, I did my reading but I am still not clarified with it..
I am not sure what is a safe number with regard to cable problems. FWIW, I bought mine directly from Sennheiser showroom in July 2016. Serial number on the wallet is 37xxx. I am assuming that my IE800 should be fresh stock as it was backordered and I collected a couple of weeks later. My cables are fine so far with light usage.
Andreeas1978
Thank You, supa! I Have called and they told me the serials all start with 505xx, a whole new shipment from Sennh last month. I never heard of such high number.. I will get mine and post back here in a few days.
majedelamine
- Jan 14, 2014
Anyone hearing any news about the IE800S. it seems the Sennheiser team worked in parallel on vamping up the HD800 and IE800.
Total: 8 (members: 0, guests: 8)
