frix
- May 7, 2012
I think the momentums are not worth their asking price when the SQ is top priority.
Strange, I find that the P5 to be quite literally the polar opposite of the IE800...Agree.Maybe they worth the price,but B&W P5 is much better.
Does the IE800 benefit from amping at all?
I'm thinking about a decent cheap amp for the iPod Classic like FiiO E11.
I currently have the 7th gen classic and iPhone 5. Are there any audible differences between the two on IE800?
Also is there any point in putting an amp to the headphone out? I know the line out on classic is supposedly very good but I don't have a LOD cable.
I miss the IE800 in so many ways. Has anyone found a replacement tip for them? I saw a mentioned of Comply 500s but the poster also mentioned that the tip got stuck in his ear.
Hey guys. I had a quick question for you guys. How would you describe the leakage of the IE800? Do you think I can use the IE800's in a quiet library setting without disturbing people or should I just go for the SE846? I'm also kind of interested in the K3003i, but I'm not sure how much that leaks either. I basically want great sound at a quiet library type of enviornement. Obviously the 846 would be the best for leakage but I'm wondering if the IE800 would also work.
Any opinions will be appreciated.
If you don't listen loudly,it won't be any problem.I compared leak with 846 when I have it,they are nealy same.
They leak nearly same.
I have all 3. According to my wife the AKG K3003i leak the most sound. Having said that they all really need what I call the 'fine wine' approach to listening. That's to say they all have their respective, but detailed sound, which benefits from not listening at ear bleeding levels. IMO the SE846, with a good seal, are the most isolating, but still go to my IE800’s most.
Ah, thanks guys. Really thanks a lot. This is why I love Head-Fi.![]()
I'm leaning toward the IE800 because I think I would prefer the sound signature more. Glad to hear I can probably listen at moderate volumes without bothering folks.
I'm out of the country at the moment for work and I realized that at my current working office I cannot use headphones because it's a little too quiet. Almost like library quiet. People use IEMs. The IE800 is around $800 here and the SE846 is $1190 and the K3003i is around $1250. I prefer a more neutral signature with some air in the treble. So I'm leaning on the IE800 because it's cheaper and also probably offers the balanced sound I want.
