88King
- Jul 9, 2010
My IE8 have developed a problem where the volume is getting progressively lower in the right earphone over the last couple of months. Now the sound sometime gets cut off on that side unless I twist the cable or unplug and re-plug the cable.
I had this problem with my 1st pair of IE8 one year into ownership, the shop where I brought it simply replaced it with a new one in stock.
But now the 2 years warranty have ran out, I’m not sure if the problem is to do with the wire or the right earphone itself.
Just want to find out if any other IE8 owners encountered the same problem.
Many thanks
P.S. Brought a replacement cable, now both earphones works fine.
Many thanks
