i just got these couple of weeks ago, and the bass just keep on getting better the more i use them, i would say treble is bit rough but not by much. also the isolation is EXCELLENT i can listen to a moderately high volume and still its leaking almost nothing. Bass is also punchy and detailed at the same time, one bad thing wich i really dont like is the seal, they are pretty hard to get good seal on and also they keep popping out from your ear if you run or ride a bike for example, but for sitting or walking they do mediocre.
For me, the only original pair I managed to get a good seal with was the dual flange tips but they had poor isolation. The UE tips offer a good seal with better isolation.
the standard tips (stock, medium size) provided the best bass and overall seal and SQ, the dual things were VERY uncomfortable, maybe i'll look into those tips at some point, thanks for the tip.
