alphaman
Formerly known as headfone
Purch'd July 2021. Pretty much daily use. Orig cable de-laminated. But connections and no wire break on OEM cable. Replaced with good aftermarket cable.
Just today: I happened w/o warning. Channel cutting out ... mostly. It is the left channel. The problem is intermittent. Might be the connector on the L driver. Are these user serviceable?
Swapped cables. Same issue. Swapped connector (same issue -- of course). Cleaned connector (delicately with toothpick with DeOx-it -- no diff.
Wiggling the connection at the mating spot MIGHT be the culprit.
But simply powering amp off/on can restore sound--until one move one head.
The cut-out is not weirdly not always 100%. Some sound can be heard in L. Very intermittent.
Suspect solder joint. Don't think it's a blown driver -- when the sound does temporarily come back, it is full undistorted fidelity (normal).
Can't find any other reporting of this. Let me know!
There is no disassembly tutorial or tips.
Maybe how does one remove the red thing:
