I think that the small hole in the middle of the absorber is what is responsible for the low frequency boost. I did some experimenting on my HD800 and made my own centre hole absorber for 6Khz and centre resonator to boost the very low frequencies. To be honest the 6kHz reduction alone is easily performed and I managed to very very closely match my 6Khz and 6.5Khz loudness to the 5 and 5.5Khz which resulted in better high frequency perceived detail, better depth perception of the image and of course loss of treble spike (which never really bothered me until I realised the difference when removed!). IMHO matching the 5kHz range to the 6kHz is imperative to the best overall performance. You should not aim to reduce 6 kHz and 6.5Khz levels completely but to seamlessly match them to the 5 kHz range according to your personal ear and not a graph from a microphone as the frequency responses from microphones although extremely informative do not have the same response curve as your individual ear.
I was not successful when experimenting with the absorber/ centre resonator for low freq combo. My bass was increased but muddy. But..the centre hole increases the bass and you can also show this mathematically using the helmholtz equation for an open cylinder connected to a volume of air. The modification is easy and can be undone with no damage to the HD800 and I would recommend just doing the 6 kHz band only if you already have an hd800 which has a 5dB bass response as on your certificate.
Sennheiser cannot create one headphone that matches all people's hearing response. They have given you two options for how they handle the 6kHz peak and you will most likely fall somewhere between the two unless you custom match your headphones 5,5.5, 6 and 6Khz response to your ears natural rolloff.
Again this is all my own personal opinion and I am really interested in working with people also with a scientific knowledge of acoustics to further increase my knowledge of a hobby I value dearly. If you are interested in the steps required to match your 5 and 6 Khz bands just ask
