phonomat
- Jan 28, 2013
Those frequency ranges are normally given for either -3dB or -10dB vs. a reference point (which is often 1kHz): the end points are where the level drops to -3dB (or -10dB) when compared to this reference point. Which in case of the HD800S means that its sound pressure level at 10Hz is 3dB lower than the level at 1kHz (I suppose Sennheiser uses 1kHz as their reference point, I did not check their exact method though). Same for the -10dB range, which is a bit wider as the level does not drop to 0 at once.
Thank you, plakat, I appreciate the effort, and I think I kind of understood about 3/4 of that. But I have a splitting headache today and can barely think straight, so I'll hopefull see a bit clearer when I come back tomorrow. Thanks for now!
