spacelion2077
Oh my bad. I'll ask the question there Thanks for directing me to the right place.
The HD820 wasn't an upgrade to the HD800S, it was to be a closed back TOTL headphone. From all the reviews I have read it seems as though what you might gain in bass you will lose everywhere else, but then again it's your choice. Just don't think you are getting an HD800S with more bass. Then if you really do need that then maybe consider eq?Hey there, I couldn't find a thread for Hd820, so I'm posting it here. How much of an upgrade is Hd800s to Hd820? I'm very happy with Hd800s, but when it comes to bass response, it has more to be desired
Imo the HD800S is the most comfortable high-end headphone available! This is mainly due to the lightweight construction (which doesn't feel cheap at all).so I have an opportunity to buy a secondhand 800s.
My concern is mostly related to it's comfort.
- The Sennheiser pads does not deep enough.
- The dekoni pads doesn't seemed deep enough.
(maybe it's just me but I equate having deep pads to comfortable (because my ears are not getting squished in there).
Thoughts?-+
This together with the Arya are the only headphones that I can use in summer.so I have an opportunity to buy a secondhand 800s.
Thoughts?-+
I have big ears, and my ears don't touch anything. They have huge cups.so I have an opportunity to buy a secondhand 800s.
Thoughts?-+
Maybe a Schiit Bifrost 2 ?I'm looking for a DAC for the HD800S. Do you have suggestions? Max 2000€. I have unfortunately NO IDEA what to try.
Not about how wide it but how deep are the cups/padsI have big ears, and my ears don't touch anything. They have huge cups.
There deep enough for most ears, course I’m sure if they, one’s ears, phalange out enough…. But reallyNot about how wide it but how deep are the cups/pads
Elves and possibly half-elves might have issues..There deep enough for most ears, course I’m sure if they, one’s ears, phalange out enough…. But really
I still have the stock cable on my HD 8XX, but I have a silver Wireworld top of the line cable (discontinued) and a copper DanaCable Lazuli, and I really like those. The lazuli is a bit squeezable, as if the sheathing was partially hollow (or something easily compressed, like cotton), but I don’t know what is inside and it was the first cable that helped me hear a difference from cables. The price is not for the faint of heart thoughSadly # 3 has bitten the dust..gummy and cracked again, that is 3 Sennheiser balanced cables in 6 years. : ( Never experienced that with any other cable… ever!
The oil from my skin myst be caustic with whatever rubber they use with HD800…unfortunately it’s a commonly reported issue…so not just me.
I’ve contacted Sennheiser once more but will be going 3rd party regardless.
Looking at this one, bit heavy looking though for 3m.
https://www.etsy.com/ca/listing/1032327667/cable-for-sennheiser-hd8xxhd800hd820?click_key=28640d4757c958ff352a3c0b25f40ef4d12dfb12:1032327667&click_sum=6e79a558&ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=hd800+cable&ref=sr_gallery-1-2&organic_search_click=1&frs=1&variation0=2052946770&variation1=2052946696
Have you come to that conclusion after testing?so I have an opportunity to buy a secondhand 800s.
Thoughts?-+
