thinker
- Oct 23, 2009
This may be why my 800S sounds different than my Anniversary editionTheir structure is not bulletproof, someone disassemble it and found out maybe.
Yeah I feel quite upset when they replaced default balance to 4.4... I'm not 4.4 fans when comes to desktopThis may be why my 800S sounds different than my Anniversary edition! Should I try to find out ? I don’t want to though, just as long as it sound differently to me, that is enough. I now have a couple years on with my 800S. It came with XLR and not 4.4 cables
Our of curiosity, what do you feel is the differences between the 780D and the built in 430HAD DAC?Me. Owned LCD4, Susvara, AB 1266 Phi TC and came back to HD800S. DAC is 780D and amp 430HAD, both Moon by Simaudio.
Also tried Meze Empyrean, Sony’s flagship, ZMF Verite, HEDDphone, and a few other flagships, on my gear. None were worth switching for.
It’s UHmazing isn’t it?! Very rare to come across anything else that sounds as good. The 780D is a bit more open sounding and more articulate but if I was to go back in time, I’d save myself the money, frankly. The DAC in the 430 is BEAUTIFUL and is in no need of an upgrade.Our of curiosity, what do you feel is the differences between the 780D and the built in 430HAD DAC?
(New happy owner of the 430had, few weeks in and my goodness, what a piece)
I agree on the dac! Just wanted to check and see with somebody on the 780 when I had the chance.It’s UHmazing isn’t it?! Very rare to come across anything else that sounds as good. The 780D is a bit more open sounding and more articulate but if I was to go back in time, I’d save myself the money, frankly. The DAC in the 430 is BEAUTIFUL and is in no need of an upgrade.
I’ll try and make the 780D the heart of a two channel speaker system if I can, but that’s even more money I probably don’t need to spend!!
both are 800S models, old has more closed resonator, the new "open" resonator sounds much better at least to my ears,
the open has S/N 30xxx
Are you saying your second picture is a "closed resonator" 800s, or a standard 800? I've pulled apart many drivers and the thin adhesive resonator is simply an 800s. There aren't variances in the inner diameter...both are 800S models, old has more closed resonator, the new "open" resonator sounds much better at least to my ears,
Yeah, I think he has them backwards. The old HD800's had the open ring in the middle and the HD800S's has the resonator. I haven't seen what the dual resonators look like on the Drop version of the HD8XXAre you saying your second picture is a "closed resonator" 800s, or a standard 800? I've pulled apart many drivers and the thin adhesive resonator is simply an 800s. There aren't variances in the inner diameter...
