- Jan 30, 2011
So I will use this for an example of what I did and my take away from it. So the units I used were the AK SP1k and the WM1Z and the AK380CE, I had my music on an SD card so i could just easily pop over the card from player to player. Now I have the Z1R and the HD800S as what I used for testing. So I was using 3 certain songs from Vivaldi 4 seasons and 1 song from Suantrai Adam Agee & Jon Sousa, 1 song from Stevie Ray Vaugh Texas Flood, 1 song from Muddy Waters My home is in the delta. Now with all these I played the songs all the way through. Now heres my issue, I had the HD800S on max volume for all 3 players for all the songs, it was not loud to me, the bass was non-exsistant, there was no "impact" going from highs to lows at certain points. Now I put the Z1R's on and had it turned up 145 on the AK's and 110 on the 1Z, and it was loud, there was bass, there was impact it was like "omg theres the music". Then I walked over to a Bryston with HD800S, I freaked out not going to lie it was like heaven on my ears, at it was at that very point I understood why people loved these headphones so much. So I may not go by numbers but when I have a headset plugged into a source and the volume is maxed and I an completely underwhelmed then plug it into a powerful amp then its everything I was hoping for is good enough for me to make a decision.
Might help if we know what your normal listening volume is as well. Mine is usually 65-75 dB. I had hearing damage which resulted in permanent tinnitus about 15 years ago, so I trained myself to keep the volume down. The Sony you have has a weak output anyway, so doesn't surprise me you struggled with volume on that. I looked at the AK's and couldn't find power output specs, so hard to tell what their output is like. I know there were a few people at the NZ Meet I referenced earlier who ran their HD800s at levels that were to me deafening (I'd estimate 90dB +). I guess thats the main deciding factor in this discussion - how loud is each of our "normal"?
Oh - and the LP5 Gold I mentioned earlier can put the HD800S into 100dB + territory. Its massively powerful
