LazyListener
- Nov 30, 2015
LCD-2.2, EL8, and PS500e are three that I've heard so far, there may be others
Anything near the 650's price? Again, warm tonality of 650, but "fast and clear."
That was a terrific buy as long as the drivers are ok and sound good. Just a suggestion... the hd650 is very 'modular' in build so that it would be easy to get new yokes, grills and pads giving you in effect, an almost new headphone. The strap over the head could easily be covered with a Beyer head strap which has poppers and makes the headphone even more comfortable for me.
Price would still come out pretty low. (Compared to a new one anyway)
I always worry about coating plastic with paint since it could come off again at a later date with heat expansion etc. making it even worse!!
Agree about painting but I think it also has to do with the type of paint used and the prep work one does before painting.
@stilleh
, I would suggest changing the ear pads unless they are new or fairly new
My HD650 with HM5 velour pads and VE balanced cable+adapter to 2.5mm balanced to be used with the Opus #1 and Aune M1s in the hotel room where I'm staying at the moment:
how much for the cable and converter to 2.5mm balanced ?
thanks
thanks
The cable is $20 and the adapter is $10. I also got one adapter to 3.5mm balanced and one to 6.5mm single ended (also $10 each) and iirc shipping with e-packet was about $10 as well.
https://www.veclan.com/engappliance_sel_one?eng_ApplianceVo.eac_id=8
holly mollyy:eek:
I might purchase one for my pm1 (Type B 2.5mm to 4pin xlr 1.2m $35) is this correct choice for the PM1?
holly mollyy:eek:
I'm sorry but I'm not familiar with the PM 1 so hopefully someone else can help you.
As always with VE the quality of the products are great.
The treble is definetly recessed according to my ears. But the biggest problem with the HD 650 is that is super slow and lacks clarity. The Shure SE846 has even more treble roll off than the HD 650 but it doesn't bother me at all (in combination the Chord Mojo) due to the excellent speed and clarity of the Shure SE846.
If the HD 650 had excellent speed and clarity, I don't think anyone would be complaining with the recessed treble. However it makes the HD 650 quite forgiving which makes the HD 650 quite special.
You'll hear it next to high-end headphones as they are faster and clearer. But it's not a bad thing as it gives the HD 650 the forgiving and smooth sound that it is known for.
Reading a bunch of comments about 650 being "slow" and not "fast and clear." What are some cans that are "fast and clear" but still have a warm tonality like 650? Also, can a can be "slow and clear" and if so, what are some examples?
